Old 01-31-2005, 02:08 AM
Ravin Ravin is offline
Ravin is off the scale
Hi I have a 2003 hummer H2 and my battery just died on my. I have just under 36k so I am still under my warranty. My question is the battery covered under warranty or is it a wear and tear item? Also if I need to replace it I want to get and Optima redtop but I am concerned that it doesn't have enough CCA's. The stock battery has 880 cca's and I think the optima has like 680 cca's. Is that sufficient enough CCa's
Old 01-31-2005, 03:18 AM
Here are links to discussions about the Optima's.
http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=6706011751&m=789105935 &r=928103045#928103045
http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=6706011751&m=445107689 &r=961106789#961106789
http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=6706011751&m=335105366 &r=335105366#335105366
I used the "Find" feature. Welcome to the forum.
Old 01-31-2005, 04:29 AM
Hummertech is off the scale
Yes, the battery is covered under warranty.
Old 01-31-2005, 05:13 AM
Thanks very much. I used the search earlier and saw that the redtop fit but was still wondering if it was a big deal having less CCA's than OEM. But if this battery is covered under warranty I will just get it replaced for now. Thanks
