Old 10-03-2005, 01:36 AM
x-humm x-humm is offline
x-humm is off the scale
Comming back from Las Vegas, I couldn't hit 100 mph. Everytime that I reached 98 mph the governor would kicked in and the speed would come down. Any suggestions how to bypass this governor.
Old 10-03-2005, 01:41 AM
Vincent Vincent is offline
Vincent is off the scale
Repeat Thread from 9/26
I'm not sure how to bypass the governor, but you might want to check your tire rating.
See the previous thread on this.
Old 10-03-2005, 04:12 PM
1COOLH3 1COOLH3 is offline
1COOLH3 is off the scale
It doesn't have a "govenor" it has a Limiter that is controlled by the PCM. At this time there is no way to bypass the limiter and for a good reason- H3's were not designed to go 100 mph!
Old 10-03-2005, 06:34 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 1COOLH3:
It doesn't have a "govenor" it has a Limiter that is controlled by the PCM. At this time there is no way to bypass the limiter and for a good reason- H3's were not designed to go 100 mph! </div></BLOCKQUOTE>
It is a safety limiter, your tires are only for about 104-108 mph; sustained speed.
