Old 07-09-2003, 12:21 AM
Klaus's Avatar
Klaus Klaus is offline
Document ID# 1338298
2003 HUMMER H2
Service VME - Creak Sound Upon Closing Center Console Lid - appearance button cover excessive lubrication noise part squeak #PI01141 - (05/29/2003)
Service VME - Creak Sound Upon Closing the Center Console Lid - appearance button cover excessive information noise part squeak
SERVICE VME
If a creak-type sound is detected upon closing the center console lid, the cause is within the release button mechanism. The correction is to lubricate the button release mechanism from the underside primarily along the two slider ribs using Superlube Multi-purpose Lubricant part number 12346241. It is important to use only this plastic friendly lubricant which is a GM Vehicle Care Product readily available through GM Service Parts Operations.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance. This diagnostic approach was developed for the vehicle with the VIN you entered and should not be automatically be used for other vehicles with similar symptoms.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
2003 HUMMER H2
