Old 09-30-2004, 12:32 AM
H2Finally's Avatar
I searched n searched n could not find any info. Does anyone know if there is a backup/reverse switched wire or fuse I can tap a relay to, INSIDE the cabin? Would HATE to have to run the tap from the trailer plug outside...
Thanks for info...
Can BLING Get You Home?
H2Finally's Avatar
Thanks for info...
H2Finally's Avatar
Thanks for info...
Old 09-30-2004, 12:51 AM
Klaus's Avatar
Klaus Klaus is offline
Here's a wiring schematic and a description of the backup lamps circuit.
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Backup Lamps
The backup lamp request signal is sent from the powertrain control module (PCM) to the body control module (BCM) on the Class 2 message system. This signal is based on the park neutral position (PNP) switch signal. The BCM supplies voltage on the backup lamp supply voltage circuit to the backup lamps and to the automatic day/night mirror. Voltage for the courtesy lamp supply voltage circuit and backup lamp supply voltage circuit is from the TBC B fuse in the instrument panel fuse block directly through the BCM to these circuits. A short to ground on either of these circuits will open the fuse. The backup lamps are grounded at G401.
For trailer wiring, a separate backup lamp circuit is connected through the underhood fuse block from the TRLR B/U 10 A fuse to the trailer wiring harness.
<HR></BLOCKQUOTE>
Old 09-30-2004, 02:15 AM
H2Finally's Avatar
Klaus, I read n read n could not understand your reply (you have waaayy overestimated my knowledge ). I plan to get power from SEO ACCY which is ignition switched (right?). So, for the relay signal to close the circuit when transmission is in "R", do I tap relay signal from TCB B? Light green wire? help... THANKS KLAUS!
Old 10-01-2004, 02:11 AM
H2Finally's Avatar
Okay, I can't find any fuse labeled TCB B, only TBC 2B.
I did find TWO light green wire under the dash. Can I tap to either for the relay input?
Klaus? PhilD? Anyone else did their own backup sensor/camera install? Thanks..
Old 10-01-2004, 01:20 PM
Klaus's Avatar
I haven't done a backup camera install, so I have no prior knowledge. I'll try to find out more info tonight for you.
According to the schematic, there are two LT GRN wires (one larger than the other) that connect to the I/P Relay Block. Connecting a relay to either wire should work.
I'd suggest you use a voltmeter to be sure you have the correct circuit.
The other option would be to tap into the TRL B/U Fuse (10A) circuit in the Underhood Fuse Block.
Old 10-01-2004, 04:30 PM
H2Finally's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Klaus:
I'd suggest you use a voltmeter to be sure you have the correct circuit. <HR></BLOCKQUOTE>I wanted to, but could not figure out how with engine on, gear in "R", foot on brake, torso twisted down to get under the dash to stick the voltmeter in... (my voltmeter doesn't have those aligator clip thingy)
If I don't get any update from you tonight, I'll attach the relay to one of the light green and hope for the best. Thanks Klaus!
Old 10-02-2004, 12:29 PM
Klaus's Avatar
<html xmlns="urn:schemas-microsoft-comfficeffice"
xmlns:w="urn:schemas-microsoft-comffice:word"
xmlns="http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=Content-Type content="text/html; charset=windows-1252">
<meta name=ProgId content=Word.Document>
<meta name=Generator content="Microsoft Word 11">
<meta name=Originator content="Microsoft Word 11">
<link rel=File-List href="Relay%20Block_files/filelist.xml">
<title>Relay Block - I/P</title>
<!--[if gte mso 9]><xml>
<oocumentProperties>
<o:Author>Klaus Kimble</o:Author>
<o:LastAuthor>Klaus Kimble</o:LastAuthor>
<o:Revision>1</o:Revision>
<o:TotalTime>7</o:TotalTime>
<o:Created>2004-10-02T14:18:00Z</o:Created>
<o:LastSaved>2004-10-02T14:25:00Z</o:LastSaved>
<o:Pages>1</o:Pages>
<o:Words>63</o:Words>
<o:Characters>365</o:Characters>
<o:Company>CDC</o:Company>
<o:Lines>3</o:Lines>
<o:Paragraphs>1</o:Paragraphs>
<o:CharactersWithSpaces>427</o:CharactersWithSpaces>
<o:Version>11.6360</o:Version>
</oocumentProperties>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:ValidateAgainstSchemas/>
<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>false</w:IgnoreMixedContent>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w:UseWord2002TableStyleRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
<w:LatentStyles DefLockedState="false" LatentStyleCount="156">
</w:LatentStyles>
</xml><![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Wingdings;
panose-1:5 0 0 0 0 0 0 0 0 0;
mso-font-charset:2;
mso-generic-font-family:auto;
mso-font-pitch:variable;
mso-font-signature:0 268435456 0 0 -2147483648 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
p
{mso-margin-top-alt:auto;
margin-right:0in;
mso-margin-bottom-alt:auto;
margin-left:0in;
font-size:12.0pt;
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
/* List Definitions */
@list l0
{mso-list-id:1912425263;
mso-list-template-ids:276458390;}
@list l0:level1
{mso-level-number-format:bullet;
mso-level-text:\F0B7;
mso-level-tab-stop:.5in;
mso-level-number-position:left;
text-indent:-.25in;
mso-ansi-font-size:10.0pt;
font-family:Symbol;}
ol
{margin-bottom:0in;}
ul
</style>
<!--[if gte mso 10]>
<style>
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
</style>
<![endif]-->
</head>
<body lang=EN-US style='tab-interval:.5in'>
<div class=Section1>
<p class=MsoNormal><o></o></p>
<table class=MsoNormalTable border=1 cellpadding=0 width="100%"
style='width:100.0%;mso-cellspacing:1.5pt'>
<tr style='mso-yfti-irow:0;mso-yfti-firstrow:yes'>
<td colspan=2 style='padding:.75pt .75pt .75pt .75pt'>
<p align=center style='text-align:center'>Relay Block - I/P<o></o></p>
</td>
<p class=MsoNormal style='margin-left:.5in;text-indent:-.25in;tab-stops:list .5in'>Under
the left side of the instrument panel near the brake pedal<o></o>
</p>
</td>
</tr>
<tr style='mso-yfti-irow:1'>
<p align=center style='text-align:center'>Connector Part Information<o></o></p>
</td>
<ul type=disc>
<li class=MsoNormal style='mso-margin-top-alt:auto;mso-margin-bottom-alt:
auto;mso-list:l0 level1 lfo1;tab-stops:list .5in'>12193905 <o></o>
auto;mso-list:l0 level1 lfo1;tab-stops:list .5in'>68-Way F <span
class=SpellE>Metri</span>-Pack 280 Series <span class=SpellE>Flexlock</span>
(GY) <o></o>
[/list] </td>
</tr>
<tr style='mso-yfti-irow:2'>
<td valign=bottom style='padding:.75pt .75pt .75pt .75pt'>
<p align=center style='text-align:center'>Pin<o></o></p>
</td>
<p align=center style='text-align:center'>Wire Color<o></o></p>
</td>
<p align=center style='text-align:center'>Circuit No.<o></o></p>
</td>
<p align=center style='text-align:center'>Function<o></o></p>
</td>
</tr>
<tr style='mso-yfti-irow:3'>
<td rowspan=2 style='padding:.75pt .75pt .75pt .75pt'>
<p align=center style='text-align:center'>A1<o></o></p>
</td>
<td style='padding:.75pt .75pt .75pt .75pt'>
<p align=center style='text-align:center'>L-GN <o></o></p>
</td>
<p align=center style='text-align:center'>24<o></o></p>
</td>
Backup Lamp Supply Voltage - BCM<o></o></p>
</td>
</tr>
<tr style='mso-yfti-irow:4;mso-yfti-lastrow:yes'>
</td>
</td>
Backup Lamp Supply Voltage - Junction Block - Rear<o></o></p>
</td>
</tr>
</table>
<p class=MsoNormal>Connect your backup camera relay to the larger of the two
L-GN wires in cavity A1 of the Relay Block – I/P.</p>
<p class=MsoNormal>.</p>
</div>
</body>
</html>
Old 10-02-2004, 04:41 PM
H2Finally's Avatar
Thanks Klaus!!
