04-10-2006, 02:09 PM
Hi, folks. Back again. After the rebuild of the 5 banger the engine seized at 400 miles off the repair/rebuild. Sounded like either a lifter or valve failed so you could hear it pounding into the cylinder until it seized. Apparently a rebuild will not fix this defect. I'm now in process under California's lemon law for a rebuy back of the vehicle. I do intend to replace it with another, but will "entice" the dealer to add the extended warranty without additional cost so I have some peace of mind. Any other of you rebuild customers having additional engine problems? This seems to be much more serious than originally thought so I thought I would warn you all about this potential problem. Anyone having the engine rebuilt is strongly suggested for the dealer to add on the extended warranty or you may be SOL down the road.
04-10-2006, 02:16 PM
Does it seem to matter if the vehicle has a standard or automatic transmission?
I have the five speed and drive it pretty hard up mtn passes. I downshift into third a lot going up the steep hills and run it at 5000 rpms often.
Yellow 06 H3 5 Speed ~ Luxury Off Road, Black and Chrome trim, Sunroof, Leather, XM Monsoon, Brushguard, Rail Steps, Yakima Pro 16, Mud Flaps, Hard Spare Tire Cover, pwdr coat fuel door.... .Riding like a Spirit on the Wind.
04-10-2006, 08:24 PM
I would bet, it is due to the rebuild, not the valve or head itself. The original problem with the intake valve will not cause the engine to seize; however, if not rebuilt correctly, problems will arise. When you say the valve hitting the piston, that sounds like a retainer off the valve stem, causing the valve to slip and hit the piston. If it sounded like many valves hitting many pistons, it could be the timing chain was incorrectly installed.
I hate to say this, but on any large repair like this, if the tech does not do everything just right, sh*t will happen.
That timing chain has to be perfectly aligned with the cam and crank gears, with the guides installed perfectly. Not a real hard thing to do, but the tech has to know what they are doing.
I will also say that the I-5 (and its sister the 4.2L I-6) are the hardest engines I have ever seen to replace a cylinder head. The axle has to be swung out of the way, or completely removed, to remove the oil pan, in order to get the front cover off, to remove the timing chain and guides. Literally, it is a pain in the arse to work on for a cylinder head repair. Average repair time is around 18 hours.
Good luck and hope you get one that gives you no problems.
From what I have seen and heard, there is no rhyme nor reason for this to be happening. No common thread can be found. No apparent line problems at the manufacturer, no weather related causes (all in high temp or low temp areas), and it is driving the engineering community crazy at this time.
Surprisingly, for the number of I-5s out there, the number is still low (200 or less nationwide that have been repaired, maybe another 50 being worked on but not claimed by the dealers, yet), but believe me, GM is looking for a root cause. (Sorry to say, but the greater number of failures helps to find the cause.)
We have an original captured test vehicle (been to Moab and back and driven all around MI and the south) in the back, with well over 35K miles and they are in the process of removing the head today to see what type of wear is on the valves. This engine runs perfectly, so it may not give us any clues.
04-10-2006, 10:05 PM
Well it's certainly not the engine as a whole. If it were, with the number of I-5s on the road through the H3s, Colos and Canyons, an engineering defect would have been statistically evident.
I noticed that you were very careful in not saying that the same cylinder was the culprit again. It sucks that you are having to deal with a problem of this magnitude but this does not qualify for lemon law status in most states. It's way too common for engine rebuilds to go wrong and for something to break at 400 miles is indicative of the rebuild. Best case scenario is that you get a whole new engine, head mated to block, ready-to-go so that you don't have to worry about a rebuild again.
04-10-2006, 11:26 PM
I am puzzled by the repair/rebuild rather than entire engine replacement. I would have expected that GM would prefer to study the entire defective engine.
S.
04-11-2006, 01:42 AM
hey if i blow mine up next year can i get the 3.7 ?  12k miles and runnin strong
04-11-2006, 02:17 AM
Yea wouldn't that be great.  Continue driving these rigs hard. No need to baby the motor just because of a few isolated horror stories.
S.
04-11-2006, 11:37 AM
S.
They have already pulled whole engines and sent them back that experienced this problem so they have their sample of whole engines.
04-11-2006, 02:16 PM
Only one cylinder was hitting the valve. I don't know if it was #1. It happened at 8:30 pm while idling at a busy intersection. I tried to keep rpm's up to around 1k so it wouldn't stall, but it seized as the light was changing. Carlsbad police had to block off the intersection so I wouldn't get hit as this is a 55 mph street. We sat for 1 1/2 hours waiting for a tow truck that could accomodate the H3 while my neighbors watched. Worst part was a ride home with my girlfriend in the back of a police cruiser, she's not too happy about that and neighbors are talking now!
I don't work engines hard, mostly because of $3 gallon gas prices ( I do 65 on the freeways) and I don't want to stress engine parts due to wanting long term reliability. I've never hit 5k rpm's other than a passing situation which was brief.
Now I have to deal with obtaining a buy back, ordering another custom car and waiting another 2 months after the buy back which could take months as well. This is the second H3 that I ordered as the first one, custom ordered 7-7-05 was sold off the lot August 15, 2 days before I was to pick it up by a mis-informed salesman that couldn't read the "sold" sign on the windshield.. They did add some goodies to keep me from going to another dealer while I waited for another custom H3.
Now I have to deal with the removal of my flat black Pro Comp 16x8 wheels and the 33"x12.5" Pro Comp mud terrrains (luckily I kept my original Dueler tires and rims) and the removal of my K&N air filter and intake. I haven't figured how to do this as my other car is a very reliable '04 Jeep Wrangler X and I can't fit even one wheel in there.
Any sane person would call it a day and walk from Hummer, but this is my dream vehicle so I'm going to get a third one ordered. Since I know what I want, Green, green interior, no leather, Adventure package, front brush guard, auto tranny, XM radio, monsoon sound, no chrome, I'm willing to wait as I had intended to keep this car for 200k miles or 10 years. I've bought 6 new cars/trucks in the last 11 years and have had not one problem with any of them, although none were GM vehicles.
Soory for the long post but I thought telling the rest of the story might help explain my frustration.
Pray for me.
04-11-2006, 02:25 PM
BTW, I didn't mention the "wirring" sound from my front left wheel. It hear it when I drive around 45 mph, when I lightly press the brakes or turn slightly right, it goes away. The dealer can't find that either, they only hear my 33x12" Pro Comp mud terrrains but everyone else riding with me has heard it.
California lemon law states the vehicle is to be replaced if the same problem requires 3 trips back for repairs on the same problem within the first year.
First trip back was for the engine light/rebuild, 2nd trip back was for the foul burning engine smell, ( an omen for the problems to come, I suppose), 3rd trip back was via tow truck for a seized engine.
04-11-2006, 04:16 PM
Originally posted by PARAGON:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Steve - SanJose:
S.
They have already pulled whole engines and sent them back that experienced this problem so they have their sample of whole engines. </div></BLOCKQUOTE>
I guess that is somewhat reassuring...
S.
04-11-2006, 05:43 PM
Some states' lemon law has an additional clause that the qualifies the vehicle if it was out of service for something like 20 days (also has the same problem three times clause).
04-11-2006, 05:49 PM
You can no longer order Green H3s.
04-11-2006, 07:31 PM
Pray for me.
Definitely not the same problem. With the problem everyone here is having, the intake valve guide wears for some reason, causing the engine control module to see a misfire and set a code P0300.
This bring you into the dealer, they do a leakdown test and find number one cylinder leaking. So, the remove the cylinder head, and install a new head with new valves and seals. Seats are already installed (checked today, wasn't sure yesterday).
If the engine sucked a valve, it was improperly installed by the tech. Most likely if only one valve, the retainer on that valve was not installed correctly. Technician error...but still it is a good reason for a buy back, and honestly, I would do the same thing, if in your position.
New cylinder heads have hardened valve guides and this solves the problem.
Why it does not happen on all engines is the mystery no one can seem to answer.
Right now it takes over 16 hours to remove/replace the cylinder head. In a few weeks it will take about eight hours, we worked on a new method to R&R today, and hopefully, it will be finalized in a few weeks.
Cylinder heads should become more available as time goes on, so the wait if it happens to someone else in the future, should be a few days, versus a few weeks.
There is no need for the head to go to a machine shop. All is required is the valves be lapped to the new head, and this take a few minutes per valve (20 valves x 2 minutes - 40 minutes). Installing seals, valves, springs and retainers is not hard, but if the retainers are not installed correctly, the valve will fall and be sucked into the engine. May or may not damage the piston, depending on if it stays free and just bounces around. In your case, locking the engine, makes be believe the valve jammed, the piston failed, the engine locked.
At least you would probably get a complete engine out of the next repair.
Good luck...
04-12-2006, 11:21 AM
are there any symptoms to watch for before this failure ?
04-12-2006, 06:47 PM
No, but you can continue to drive and not cause any future harm, except to the number one intake valve guide. You will have a rough idle, but driving will be ok, no power lose.
04-19-2006, 01:55 AM
The latest is the pin holding the timing chain broke, this fried the cam, but the engine still turns. Somehow, the towing trip to the dealer somehow un-froze the engine as it wouldn't turn for me. So they are installing a new cam in this rebuilt engine. I have little faith this motor will last, so Hummer is arranging to add an extended warranty of 100k miles so I can sleep at night. As everyone of the 6 new cars/trucks I've bought in the last 11 years all had extended warrenties that were never needed, I thought GM had it's act together and I didn't get it with this H3. Bad mistake. If any of you are to keep these beyond the standard warranty period, buy the extended warranty or you may be SOL.
04-19-2006, 07:58 AM
Not sure what pin they are talking about, but I still say that it is not the engine; except for the cylinder head problem. Something wasn't installed correctly when the tech replaced the timing chain, guides or tensioner. The chain is actually held in place by gears and guides, along with a tensioner in the lower left of the engine. The tensioner has a pin for releasing the tensioner, I wonder if this is the pin they are talking about, and how did it screw up a cam. A cam gear yes, but the cam?
To replace the cylinder head is an extensive repair; however, if the tech does it right, it is a no problem repair. Screw one thing up, and pieces will fly.
04-19-2006, 05:06 PM
Terrible sequence of events with that motor. It's done, should be replaced by now.
S.
04-21-2006, 01:04 PM
The service mngr. called monday and said the cam was in and they expected to have the engine rebuilt and ready by Wed. or thurs. I went by last night to pick up my sister's chevy and they said it's still up on the rack. My guess is they're having problems making this run.
I awaiting Hummer customer service to call back Mon. to check progress. They are offering to add the extended warantee to 100k miles, but they won't like hearing that the engine is still down. That may be the push they need to get me a new engine.
Pray for me.
