Old 02-10-2006, 02:09 PM
H3inAZ H3inAZ is offline
H3inAZ is off the scale
Just under 3000 miles and according to the dealer, the electronic controller within the encoder motor has failed.
The encoder motor shifts the transfer case from high range to low.
The symptom was as you were driving it shifted into low on its own and could not manually be put back into high. It put itself back into high after the ignition was turned off while setting awhile.
Of course the part is ten days away. They did provide us with a Cadillac SRX which drives like a stationwagon..
Old 02-11-2006, 12:37 AM
Desert Dan's Avatar
Coming home in low range would be a slow trip.
That would suck
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 02-11-2006, 12:05 PM
Disnydad's Avatar
Disnydad Disnydad is offline
Disnydad is off the scale
Cadillac SRX ain't too shabby. Is it an AWD?
2006 H3
2004 Cadillac SRX
Old 02-11-2006, 02:30 PM
HummerJim's Avatar
You must have been going awfully slow, because anything over 15 mph would probably lock the tires, spin the truck, and strip gears in the transfer case, going from high to low range. I saw a Trooper manually crunched from high to low range offroad once and he threw pieces of transfer casing and a few gears.
Old 02-14-2006, 12:19 AM
Yes, I believe it is AWD. It's really nice but we prefer the H3's drive over the SRX.. Oh yes very low speeds thank goodness!
Old 02-14-2006, 02:49 AM
H3 Guy H3 Guy is offline
H3 Guy is off the scale
Happened to me as well. I ended up turning off traction control, turning it off, and pulled the battery cable and 10 minutes later (and some gentle words) she came alive again. Looking back I realize everything I did had nothing to do with the getting stuck in 4 lo, but I was not about to 20 miles to the nearest paved road in 4 lo. My guess is computer glich.
