Old 02-26-2006, 12:22 AM
zeros zeros is offline
zeros is off the scale
hi i added a factory spare tire carrier to the back and eveything went very well... i just have to get power to the tag light that is in the center on the back of the spare tire... but im not sure were to get the power from? it looks like maybe i need anthor adaptor splitter or something that i am missing... or is their a place i can just plug it in to? thanks for any help
Old 02-26-2006, 12:35 AM
VTSTOMPER is off the scale
Are you in a pre 2005 SUV?
Just tap into the stock light you currently have - behind the bumper should be the place to do it. I assume your taking your other light off?
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 02-26-2006, 05:41 PM
im still not sure where to attach the wires going to the new light on the spare tire carrier... their are two wires black and white with a connector on the end... but i looked under the back bumber and im not sure were to connect it...or even if i spliced them into somewhere? anyone have a idea or a diagram?? thanks alote!
Old 02-27-2006, 03:33 PM
Black wire to brown wire under back of truck, in a bundle on the RH side. White wire to chassis ground. If you have a question on this, take the truck to someone who is experienced in this type of stuff. Incorrect wiring mods of this type can 'let the smoke out of' the Body Control Module--it's a $500 part buried underneath the dash.
Old 02-27-2006, 04:05 PM
ok great ...thanks for your help! ill see what i can find..
Old 03-01-2006, 01:20 PM
i found a brown wire under the right hand side.. grouped togther with a red and back wire.. would that be the correct brown wire? thanks
Old 03-02-2006, 04:10 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Brown wire on the trailer connector, all wires on the trailer connector are clearly marked, brown wire should be park lamps. Then just find A good ground. Left side of frame right behind bumper is A factory ground.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 03-02-2006, 10:47 AM
what would be the easest way to get access to the trailer connector... how would you unplug it? its hard to see from underneath.
Old 03-03-2006, 01:10 AM
HUMTECH's Avatar
Easiest way remove the 4 torx screws and remove connector from bumper and then you will be able to see it to disconnect it. There is a tab to squeeze and then it just pulls out.
1998 Chev Z71
Old 03-03-2006, 01:16 AM
thanks! ill give it a try!
