Old 05-15-2007, 05:07 AM
tukrhum tukrhum is offline
tukrhum is on a distinguished road
Default front locker
was told someone came out with a front locker for h3?? can not find!
anyone know to get gears for front diff. only thing i can find is 4:56
same as factory.
thanks for any info glenn
Old 05-15-2007, 06:09 AM
Default Re: front locker
i wouldant put one in the aluminum housing but be patient , all hope is not lost
Old 05-15-2007, 07:31 AM
Do you just want to be able to grenade it faster?
Old 05-15-2007, 03:45 PM
is it spin and grab or wheel hop what is braking diffs??? would the locker stop some of this with throttle control???
Old 05-15-2007, 04:23 PM
Cast iron would only be part of the solution.
No tukr, it is "housing flex" that causes the teeth to be stripped from the ring gear.
However, it is a 7.25 inch ring gear. Waaaay to small for a 5K lb + 4x4.
I would not put a locker in a 7.25 inch front diff. Needs to be at least 8.0 and even then you have to be really careful.
I'm not sure a front locker is even needed. I've never, to this point been in a situation where someone said, "Hey Beebs, if you had a front locker, you could have stomped that obstacle".
Old 05-15-2007, 05:54 PM
Eight inches or more would be ok (differential you perverts), and yes, as NEO stated, be patient....
I agree with Bebe, how often is a front locker really needed? However, if you do need it, it would be nice to have.
Old 05-15-2007, 06:06 PM
Desert Dan's Avatar
A front locker would be useful in some situations. We are waiting patiently
I would rather have control over the front diff rather than having traction control/abs kick in.
I have had ARB's front and rear in a YJ and my Rubicon has lockers front and rear. No complaints.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 05-16-2007, 03:06 AM
sorry bro i told you wrong i thouhgt it was out, Sedona lifted h3 right?
Old 05-16-2007, 03:47 AM
no problem Sam. yes lifted h3. had great week end!!
Old 05-16-2007, 04:53 AM
deserth3's Avatar
deserth3 deserth3 is offline
Is there something implied that you can't tell about yet??
Old 05-16-2007, 04:57 AM
Old 05-16-2007, 06:46 PM
deserth3's Avatar
Love those bananas
