Old 06-12-2006, 11:48 AM
byzance byzance is offline
byzance is on a distinguished road
Default some questions about H3
I want to buy H3
As we do not have so many expiriance in Serbia with Hummer I wanted to ask something about using Gas instead petrol
This equipment in Germany cost about 4.500 US $ so if it is worth before ordering maybe I can do it in US if it is cheaper
Also I wanted to put refrigerator between seats as I had in my Diahatsu FEROZA do you have any recomendaton, type, model etc
Also what audio/video/navigation you recomend
Thanks a lot
Regards from Serbia
Old 06-12-2006, 05:01 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
Default Re: some questions about H3
Serbia? I'd think a heater is a better idea than a refrigerator...
-Brian
http://www.hummerguy.net
Old 06-12-2006, 07:37 PM
Wisha Haddan H3's Avatar
I don't understand your first question. Are you trying to convert from liquid gasoline fuel (petrol) to a gaseous fuel like propane or hydrogen?
Old 06-12-2006, 08:31 PM
This is combination petrol with propane
Old 06-12-2006, 08:40 PM
fourfourto's Avatar
Info on this would be interesting,I dont beleve they do this in the us and might void warranty.
Look on ebay for a fridge a console type wouldnt work in the front because it has a console.If you put one between front and back seat it will interfere with rear cup holder.I put mine in the cargo area.(lots of options and will fit a big one if needed.)
I like my eclipse AVN easy to use ,they make different types depending on how much you are willing to spend.
Old 06-12-2006, 09:02 PM
Thanks fourfourto for pic
I found this and it seems that it fits between seats
Old 06-12-2006, 10:30 PM
fourfourto's Avatar
I made a note of the measurements from console to rear seat. 12 inches to seat only 8 inches with the cup holder out.Also if its higher than 13 to 13 1/2 inches it will interfere with console lid opening.
Remember also that the 12 volt accy outlets are powered all the time.You should run it off the key.powering the fridge only when trucks running.
use the search button up top for wiring info.
