07-07-2006, 10:16 PM
Busting her cherry Sunday....
First time with the 3 off road.... suggestions? I have removed my nerf bars, disconnected my sway bars, removed my center caps, I have a good mobile tool kit (complete with new tie rod end). I am going with others that have a winch and other serious gear. Not going though too hardcore stuff- taking it easy to start. Any and all suggestions are welcomed.
matt
cincy
matt
cincy,oh
LOCKERS RULE!! Open Diffs DROOL!!!
2006 Black Hummer H3
07-07-2006, 10:22 PM
Re: Busting her cherry Sunday....
Have a spotter outside of the vehicle to direct you as you go through some of the more difficult terrain. You will be glad you did. Also, work the brake and pedal together. Use the brake pedal to control the speed of the truck and not the gas. It will move more smooth through the obstacles you encounter like a big tree, etc. Also, keep your thumbs outside of the steering wheel incase the wheels whip around on you. It could break your thumbs. The hardest part is getting the smile off your face at the end of the day.
____________________________
07-07-2006, 10:23 PM
Originally Posted by humma_H3
First time with the 3 off road.... suggestions? I have removed my nerf bars, good disconnected my sway bars, not a good idea onroad, not really necessary offroad removed my center caps, I haven't lost one yet. I have a good mobile tool kit (complete with new tie rod end). good idea I am going with others that have a winch and other serious gear. very good idea Not going though too hardcore stuff- taking it easy to start. Any and all suggestions are welcomed.
matt
cincy
Best suggestion.....have fun!
07-07-2006, 10:27 PM
I wouldn't dissconnect the sway bar. Also, I haven't had any issues leaving the center caps on the wheels. Just make sure the side steps are off and the mud flaps are off. Make sure you get the rocker panel protection if you are planning to winch over stuff.
07-07-2006, 10:48 PM
I agree with the above comments but I would take off the center caps. I mangled one on the first trip out. Have a great time.
07-07-2006, 11:19 PM
have a great time, it will be worth the wait
07-07-2006, 11:30 PM
wait? what wait? just got it three weeks ago.
Thanks for all the advice- I have been wheeling many times, but never with my own vehicle. very pumped to get it out there.
So leave the sway bars? I was always told the opposite.
lower tire pressure? if so, what psi for best results? Also I am getting clear vynil to protect the paint on the fender flares.
matt
cincy
matt
cincy,oh
07-07-2006, 11:31 PM
another vote for removing the center caps. have a good time and take a bunch of pics.
07-08-2006, 12:25 AM
matt
cincy
Don't worry about the sway bars. Sewie is right. Right now its not a big deal.
YES. Lower your tire pressure. 21-22 PSI is good for the stock Bridgestones.
Pull off the center caps. It takes 10 seconds and could save you $$$. Better safe than sorry.
Do a search on and read up on BTM. If one of the more experienced people is familiar with it have them demonstrate/explain it. Knowing BTM will make you MUCH happier.
Have fun. Be safe. Repete.
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
07-08-2006, 01:28 AM
did a search on BTM... came back too many to display- what does it stand for, maybe I have already heard if it.
Very much plan on repeating.
matt
cincy
matt
cincy,oh
07-08-2006, 01:35 AM
BTM = Brake Throttle Modulation (basically two-footing it)
Old article about the H1 but it explains how it works.
http://www.off-road.com/hummer/tech/3-wheeling/
07-08-2006, 01:52 AM
very good... thanks
matt
cincy
matt
cincy,oh
07-08-2006, 01:58 AM
AND TAKE LOTS OF PICS!!!!!!!!
Have fun but don't be to rough with her the first time. Next time you can bang the hell out of her.
07-08-2006, 02:07 AM
Way to change the subject HI.
07-08-2006, 05:33 AM
07-08-2006, 05:35 AM
and it gave me wood.
07-08-2006, 05:40 AM
BS!!! If she's not a keeper or you just want to see what she'll take, beat the hell out of her the first time out!!! No smilies here, bish!!!
07-08-2006, 01:41 PM
I see this has taken a wicked turn... so I will join in.
What if I get stuck? Should I pull out? Call her the next day?
matt
cicny
matt
cincy,oh
07-08-2006, 01:47 PM
Do you have rock bars?
07-08-2006, 02:05 PM
HummerGirl (HC) set up her rig with rock bars and 33" BFG's. Broke an axle the first time out with the new set-up, but had a lot of fun!
