11-04-2006, 10:10 PM
GOBI Stealth HIGHLIFT
GOBI has the Stealth rack mounts done!
I have the highlift mounted and axe/ shovel brackets on. It took about 5 minutes to mount each set. It mounts the same way the feet on the rack mount. They bolt into the factory track without drilling. The highlift sits below the roof rack line. So really if you wanted one of these and didn't have a rack, it would still work too wich is nice IMO.(only on the axe mount would I try this though. The highlift one braces up against the rack for support.
11-04-2006, 10:12 PM
Re: GOBI Stealth HIGHLIFT
All the handles lock on too.
11-04-2006, 10:14 PM
you get clearance of just over 1/4" to touching the truck. So it stays in close to the body of the vehicle instead of stick wayyyyy out.
11-04-2006, 10:17 PM
Here's the axe shovel mounts. These mount up the same way. I don't have the shovel or axe to go on there yet, but figured I'd post it up anyhow. The shorter shovels with the handle will fit, but you have to adjust the bracket up higher which does make it sit just above the rack line. If you use a straight handle it fits super low. The axe it really doesn't matter on.
They lock also.
11-04-2006, 10:21 PM
one more from the side.
11-04-2006, 11:01 PM
looks great. Thanks for the detailed pics.
I'm Gonna crazy you my body
11-04-2006, 11:29 PM
Looks AWESOME!! Love those beadlock rims!!
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
11-04-2006, 11:44 PM
Nice Tim.
11-06-2006, 01:58 AM
Tim- Your tuck looks sweet! What brush guard is that? Also what tires are those?
Would the hi-lift mount work on the side of a SUT bed rack?
Very cool design. It looks like you could get it down without having to climb onto the roof.
11-06-2006, 03:01 AM
Tim,
Sweet looking truck man!!
I would also like to know which wheels and tires you have. I have a Yellow '03 and was thinking about going black with a set of wheels...
TIA!
-Matt
06 - Black Caddy SRX
11-06-2006, 03:06 AM
Tim,very nice, where did you get the four lights in the grill? also is that a warn bumper?
11-06-2006, 05:03 AM
Black 05 Hummer H2. (STILL WORKING ON IT!)
11-07-2006, 01:32 AM
Very nice Tim! It fits nice and snug.
11-07-2006, 01:34 AM
That's what all my beotches tell me.
11-07-2006, 01:35 AM
PIAA 004XT's. I made the lightbar.
Yes. That;s the WARN bumper.
11-07-2006, 01:54 AM
Looks very nice Tim!
11-07-2006, 04:15 AM
I have this feeling, that you may be the firest to try it.
I'm not really sure if it does it or not.
That's a stainless PC'd real wheels brush guard.
Tires are 37" X 13.50 x 17",4.75 backspace procomp extreme AT's http://www.procomptires.com/xtatapps.htm mounted on Procomp's http://www.procomptires.com/series1079.htm but in black. They just released these the end of Oct. I added their extreme rings also. http://www.procomptires.com/xtremerings.htm
11-08-2006, 05:22 AM
Check PM tim......
11-08-2006, 06:18 PM
Looks like the high lift will hit the paint if you happen across a pot hole in town?
Otherwise like the set-up, nice rig!
11-08-2006, 06:49 PM
It can't bend or flex at all. Trust me: I tried before I drove around.
