Old 08-23-2006, 07:11 PM
Mojosan's Avatar
Mojosan Mojosan is offline
Mojosan is on a distinguished road
Default "Balancer" needed to keep #7 & #8 cyliners cool?
I placed an order with Teakatoys for afew things and when they called to "confirm" my order they recommended I get a balancer http://www.teakatoys.com/ProductDetails.asp?ProductCode=HEA%2DHDP1551&CartI D=1
I will be taking very few long trips, and I'm not going off road. Do you think this is needed?
2001 AMG H1
2004 Cadillac Escalade ESV
2006 BMW 525xi
2006 Mercedes SL500
Old 08-23-2006, 11:02 PM
Beastmaster's Avatar
Beastmaster is off the scale
Default Re: "Balancer" needed to keep #7 & #8 cyliners cool?
It's a cooling kit. The cooling ports on cylinders 7 and 8 are blocked with a plate. This kit basically opens the flow so that the area doesn't get heat soaked.
I've reviewed something similar.
http://www.azhog.org/hedger_cool_kit...r_cool_kit.htm
They all do the same thing.
M101A2 Trailer
Old 08-23-2006, 11:04 PM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
It's a worthy modification, as it will also improve the heater performance.
Old 08-24-2006, 02:05 AM
Ground hawg's Avatar
Ground hawg Ground hawg is offline
Ground hawg is an unknown quantity at this point
Go to your local hardware store and get the parts from the pluming section. It will cost you around $30 for the hose and brass fitings
