Old 09-03-2006, 07:21 PM
Wisha Haddan H3's Avatar
Default e-locker failure
My e-locker failed on the trail yesterday. It worked at the bottom of the trail, but later when I engaged it the light would blink for 15 secs and then turn off. Tim and I tried every combination we could think of to reset it, but nothing worked. btw this was in 4-lo at a complete stop. And yes I was pushing the right button
There's no message in the DIC and no codes according to onstar. I'll call the dealer after the holiday, but is there anything I can try in the meantime, like disconnecting the battery cable for x minutes? Is there a fuse for the e-locker? I couldn't find one in the fuse box.
Old 09-04-2006, 03:37 AM
Boar-Ral Boar-Ral is offline
Boar-Ral is an unknown quantity at this point
Default Re: e-locker failure
There is a servo that is responsible for switching modes in the transfer case.* I have heard of incidents where there will be a servo failure, but this is usually reported through the DIC.* It still might be a possibility.
Old 09-04-2006, 04:11 AM
IMO, Don't disconnect your battery. Take it into the dealer. You may have luck and reset everything and it will work a few more times. It's better to let them hook your up your truck to their Tech2 (I think that's what they use) to figure out the issue. That could have been bad if you were in teh rock garden and it failed it there... or on something like radiccal hill.
Mine will be down there next week as well.
Front end alignment and rebalance on one wheel. Other than that, I detailed the whole truck today. Even painted up the UCP and skids.
Old 09-04-2006, 05:36 AM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
It sounds like the encoder motor is seized, thats the actuator on the t/case where the wires go into. KenP could show you where it is.
Old 09-04-2006, 06:24 AM
Guess I wasn't clear ... the transfer case is fine. It shifts between 4lo and 4hi locked/unlocked just like butter. It's the rear locking differential that won't engage.
Old 09-04-2006, 07:01 AM
deserth3's Avatar
deserth3 deserth3 is offline
I'm not an expert but I'd check the wiring going into the diff. There's most likely a connector and it may have come disconnected.
If that don't work take her to the dealer.
Old 09-04-2006, 02:22 PM
Worth a try, but it should set a code (C0388), and turn on the indicator lamp.
It is a simple circuit, the TCCM supplies 12-volts to the rear locker solenoid on the (L-Green wire), and supplies a ground via the black wire to the TCCM. This is also the monitoring circuit. If the TCCM sees the request for axle lockup via the switch, and it energizes the actuator, and no feedback signal is obtained it should set the code.
Wisha Haddan H3:
Try this....
Go back to normal 4-wheel, then bring the vehicle down to less than 3 mph or to a full stop, put the trans in neutral, engage 4-wheel low lock and immediately engage the rear locker. Might work....
Old 09-05-2006, 05:37 AM
Thanks F5. I tried that and it seemed to work ... at least the light stayed solid this time
I didn't have a chance to really test it tho, so I don't know if it's actually locking the axle. I'll have service check it out this weekend when I use my free oil change.
Old 09-05-2006, 12:35 PM
Easy to test, hang one of the wheels off the side of a cliff and see if it turns at the same speed as the other wheel.
I would guess that if the light stays on, it is engaged. The TCCM should turn off the light if not engaged, and flash if it can't engage, then turn it off.
Old 09-05-2006, 03:00 PM
Or find a neighbour's new lawn and drive in a tight circle.
Old 09-05-2006, 03:08 PM
this is a good test too
Old 09-05-2006, 04:00 PM
Wisha,
If you recall I had the same problem on the Rubcon. Well, BABHUMV took the center panel out and plugged the switch back in, and it worked fine, but the button was still sticky.
The dealer replaced the entire switch panel and now it works great.
Apparently the module behind the switch was bad.
Old 09-05-2006, 07:32 PM
Originally Posted by HummBebe
Wisha,
Wonder if I got a bad module too. Thanks bebe, I'll bring it up when I call service
Old 09-05-2006, 07:59 PM
Good posibility, in addition, if the center trim panel is ever removed, make sure the connector's lock (blue sliding plastic thingy) is pushed in after the connector is FULLY seated into the module. Not seated, it can cause intermittent problems since it may wiggle a bit.
