Old 09-28-2006, 03:30 AM
SDH3 SDH3 is offline
SDH3 is off the scale
Default Subtle changes in the 07 H3
Yeah, the cubby hole in front of the trans shift, the DRL as headlights, the added 22 Hp, and the horn. While these items may seem minor I appreciate them. The cubby hole is perfect for cell phones or other similar items. The DRL no biggie, and if you don't like it you can flip on the amber and fog lights. 22 more horses are a plus especially on hills, and I feel it moves along very well without going full throttle. The horn suprised the sh_t out of me. I accidentally hit the panic button on the remote, and it is 10x louder with a higher pitch. Progress though small is a good thing. I like it.
Old 09-28-2006, 03:33 AM
Default Re: Subtle changes in the 07 H3
cool thanks for the update , the horn swap should be easy for us with 06's
Old 09-28-2006, 03:36 AM
Grape Ape's Avatar
Grape Ape Grape Ape is offline
Grape Ape is on a distinguished road
The cubby must only be on the automatics. The 5-speed does not have one.
Old 09-28-2006, 03:44 AM
marin8703's Avatar
would a horn swap involve just swaping the hon itself or some other changes too?
Old 09-28-2006, 03:45 AM
whaaaaT whaaaaT is offline
whaaaaT is on a distinguished road
i have an 06 and i have all that minus the horsey's. also i think the headlights on looks better than the markers.
Old 09-28-2006, 03:52 AM
i would think just unpluging the old one and unbolting then replace with the new . But with so much data running thru the BCM it may control this too might need a voltage increase , etc.
F5 tell us about a horn swap
Old 09-28-2006, 04:31 AM
fourfourto's Avatar
HMmmm... short out the 06 horn and bring it in for replacement.
Think that will work... something to think About
Old 09-28-2006, 04:44 AM
Hummer Guy's Avatar
Hummer Guy is off the scale
I'm not an electritian by any means, but most of those run on the standard 12 volt systems, so you could probably swap it out pretty easily as long as the plug/wiring is the same...the cubby and lights is on about half of the 06s as well...mid-year changes
-Brian
http://www.hummerguy.net
Old 09-28-2006, 05:03 AM
Good info on the '07, horn swap sounds promising.
S.
Old 09-28-2006, 05:09 AM
how about submerging it
Old 09-28-2006, 05:58 PM
Is that avatar a camo H3? If so, did you post a pic of it yet?
Old 09-28-2006, 07:03 PM
Hmmm2's Avatar
Hmmm2 Hmmm2 is offline
Hmmm .. maybe "Captain of the Titanic" can let us know how to do it!
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
Old 09-28-2006, 07:07 PM
fourfourto's Avatar
Do you think the dealer would replace it with a 06 or 07 ?
Easy to short out just unplug it and hook it up to 110 house current a little sparking and it would be fryed.
I have a air horn so its not that important
The 06 horn sounds like a wiennie horn.
Old 09-28-2006, 07:19 PM
mtc mtc is offline
mtc is on a distinguished road
I think they also moved the dome light further to the front of the truck, at least the 06 I test drove seemed to be alot farther rearward.
Old 09-28-2006, 07:36 PM
Wisha Haddan H3's Avatar
You know, I don't think I ever heard an 06 horn, and from what you guys described I was expecting a VW beep-beep when I got 07. But it sounded fine to me. I just figured if you guys were putting semi and train horns in your rigs, you would never be satisfied with a factory horn anyway.
Old 09-28-2006, 08:36 PM
I think the horn is different and in a slightly different location or at least pointing in a different direction. The shock for the rear door is different making the door much easier to shut. The airbox has some changes. The 07's have an air pump to get the cat(s) lit off sooner. The oil filler location cover is aluminum vs. black plastic/nylon for the 06's.
Old 09-28-2006, 09:04 PM
Hmmm2's Avatar
Depends if you have a sunroof or not. If you have the sunroof, then the dome light is further back.
Old 09-29-2006, 12:00 AM
Lex_Ordo
I'll have to go up to the dealer and hit the '07 horn. I think my mid year '06, has all of these incorporated changes made part of it already.
March '06 Build.
I test drove the '07 and didn't notice anything different inside or out, but the aluminum oil cap might be a real treat to change , as well as the horn if it hasn't been changed already.
Old 09-29-2006, 01:01 AM
H3HUMMER's Avatar
H3HUMMER H3HUMMER is offline
H3HUMMER is on a distinguished road
I was going to change mine but GM has a special plug the 07 must have the same plug time to go to the dealer and hear it.
Old 09-29-2006, 01:05 AM
H3HUMMER's Avatar
Brian you have a great website i always been checking it out.
keep up the good work
