09-24-2006, 03:55 AM
Well, they say it happens in 3....
Last week when I decided to rotate the tires, I came across a few problems...
First, the damn stud broke...
While looking at the stud, I noticed the shock seemed like it was at a wierd angle...WTF?
Then out of the blue, I've got a serious vibration at 45 mph. I pulled the driveshaft (my newly made aluminum one) and the guy at the driveshaft shop said it had a bend in it. He says the way the bend is in it that it's from torque.
I assured him that there wasn't enough torque to bend a driveshaft that they use in 700HP vehicles.
Anyway, they're making a new one, I'm going back to steel instead of aluminum...
Hopefully this was the last of my set of 3.
My first thought was that these were all related but I haven't been offroad in a LONG time, didn't drive over any hybrids.... really I have no understanding or rational explanation why these 3 happened at the same time.
Mark
09-24-2006, 06:20 PM
Re: Well, they say it happens in 3....
Good thing you rotated the tires, huh?
09-24-2006, 08:13 PM
Yeah, no crap.... can't wait until I do a 100K tuneup...lol.
09-24-2006, 10:03 PM
Maybe the broken shock was absorbing the driveshaft bend as transfered to the broken stud.
09-29-2006, 01:52 AM
i've seen that same problem when the transverse canooter valve jams....
2009 H2 Silver Ice LE
09-29-2006, 01:55 AM
Mark, do you lift?
Apparently you are too strong. You broke the wheel stud just after applying so much torque to the lug wrench that it was twisting up the rear end bending the shock ram and bending up the drive shaft.
09-29-2006, 10:57 AM
Originally Posted by PARAGON
Mark, do you lift?
God I wish one of ya'll had an answer. I think the correct answer is shiet happens...
Mark
09-29-2006, 01:42 PM
Take a good look at your panhard bar and your trailing arms. The wheel stud could be a coinkydink (although I'm not a huge fan of those) but the shaft and shock ram sounds related.
Sounds as though the rear end might have got out of alignment
09-29-2006, 07:44 PM
Sorry about your problems!!
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
09-30-2006, 06:16 PM
Hey Hummbob....I just saw a model of your rig in the Hummer Stuff catalog......
09-30-2006, 08:35 PM
Crush I agree with PARAGON. I would look at alingment. I would be looking at the bushings real close. If You do not put something on them so You can really twist the arm to see movement it can look good and not be close to half good. But it looks like something is allowing the axle to move forward or back somehow. But, it could be a page out of Murphy's Law. I hope it is simple fix good luck.
TAZ
10-01-2006, 05:28 PM
maybe you are not a very good mechanic and should let others rotate the tires next time
10-03-2006, 11:23 AM
TAZ
Taz,
I've been thinking about what you and Paragon said. I have taken a look at the panyard arm, trailing arms and bushings. From what I can physically see, everything seems normal. I think however an alignment will tell me more. (though Murphy's Law is more my luck...lol)
How is it my fault that left was loosy, right was tight...
10-03-2006, 02:34 PM
That's the problem right there, it's the opposite on wheel lugs so you turn in the direction of tire rotation.
10-03-2006, 03:49 PM
hahahahaha but only on the left side of the truck
10-04-2006, 06:21 AM
Damn, I've got a problem.
