Old 09-21-2006, 05:43 PM
Winneconne Winneconne is offline
Winneconne is off the scale
Default maintenance
Guys,
I have 18K miles on my 03 H1 and was interested in any maintenance tips you could provide. I love this monster.
Old 09-22-2006, 05:17 PM
leenigen's Avatar
leenigen leenigen is offline
leenigen is off the scale
Default Re: maintenance
I have a significantly older and higher milage truck but, as you've probably heard, the steering and suspension is always a problem. Be sure to grease everything every oil change to try to prolong the life of these parts. Keep a close eye on wear of all these parts in order to keep from ruining those expensive tires. Other than that I just stick to the usual maintanance stuff.
Old 09-22-2006, 06:38 PM
ssgharkness020147's Avatar
Hey Winnecone,
Shoot me an email @ ssgharkness020147@yahoo.com
I'll tell you what to do, where you can get the fluids/parts (you may need), and where to get it serviced if you do not have a good shop.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 10-20-2006, 07:13 PM
hmcoleap's Avatar
hmcoleap hmcoleap is offline
hmcoleap is on a distinguished road
Grease, grease, grease - find all the grease fittings and keep them well-fed. Also, each time you are under the truck, check the halfshaft bolts to make sure they aren't backing out on you.
Other than that, typical schedule of fluid changes and filters, and you should have a happy monster!
Originally Posted by Winneconne
Guys,
-- Manny
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
manny(at)serious4x4.com
http://www.serious4x4.com
