Old 11-11-2006, 08:15 AM
Default For Dochummer
Doc,
Here's the repair list. I'll post two below that might be what you want. Let me know if that's not what you need and we'll keep trying.
Lubricant Replacement - Front Drive Axle
Differential Carrier Assembly Hole Plug Replacement
Vent Hose Replacement
Vent Hose Connector Replacement - Front Drive Axle
Inner Shaft and/or Housing Replacement - Front Drive Axle
Inner Axle Seal and/or Bearing Replacement - Front Drive Axle
Differential Drive Pinion Flange/Yoke, Seal, and Dust Deflector Replacement - Front
Differential Carrier Assembly Bushing Replacement Differential Carrier
Differential Carrier Assembly Bushing Replacement Inner Axle Shaft Housing
Differential Carrier Assembly Replacement
Differential Carrier Assembly - Disassemble
Differential Case Assembly Disassemble
Differential Case Bearings Inspection
Differential Case and Gears Inspection
Pinion and Ring Gear Inspection
Thrust Washers, Shims, and Adjuster Sleeves Inspection
Differential Case Assembly Assemble
Pinion Bearing Cup Installation
Pinion Depth Adjustment
Differential Carrier Assembly - Assemble
Backlash Inspection and Adjustment
Differential Carrier Assembly - Final Assembly
Gear Tooth Contact Pattern Inspection
