Old 01-26-2007, 07:01 AM
UNIQ-Import UNIQ-Import is offline
UNIQ-Import is on a distinguished road
Default Wiper/washer
Hi everyone.
I got a 2004 H2.
A few month ago, my front window washer startet spraying water on the window.
Only way to stop this, was removing the releay in fusebox.
After a few day, I replaced the relay, and problem was gone.
A month ago, I got the problem again. I removed the relay, and replaced after a few days, and problem was gone again.
Today, the wiper starts, and keep on going, and I cant stop this.
Is this a known problem ??
Thanks.
Paw
Old 01-26-2007, 08:36 PM
mdoyle mdoyle is offline
mdoyle is on a distinguished road
Default Re: Wiper/washer
Sometimes a relay will either loose it's spring or the contacts will stick together from over-current. Sometimes it's just a bad relay, or sometimes the motor or driven load requires too much current damaging the relay.
I think the first thing to do is replace the relay, then if the problem returns you can look for more expensive problems.
Old 01-26-2007, 10:20 PM
partsguy partsguy is offline
It's the wiper module,every Hummer dealer stocks them.
Old 01-28-2007, 12:39 PM
I did test the relay.
They work ok :-(
I am afraid the problem is more expensive.
Old 01-28-2007, 08:52 PM
emeldahay's Avatar
emeldahay emeldahay is offline
emeldahay is on a distinguished road
I had to replace my wiper motor unit when this happened - its not a cheap part - at least not if your in the UK - cost a couple hundred pounds IIRC.
