Old 02-16-2007, 04:22 AM
RazM's Avatar
RazM RazM is offline
Default Right turn signal not working...
Heya group,
Tonight my right turn signal started to act funny. When I put it on, I noticed the "chime sound" was running really fast, about double the speed of what it normally does. I checked out the lights and in the front it's working (but it also flashes at about double the normal speed), and the rear blinker isn't working at all.
The left signals are working normally, and at a normal speed.
Any idea what this might be? Fuse, or bulb went out in the back?
Old 02-16-2007, 04:35 AM
RazM's Avatar
Default Re: Right turn signal not working...
BTW, the rear lights and brake lights are working normally, just not the blinker.
Old 02-16-2007, 04:54 AM
lamric's Avatar
lamric lamric is offline
lamric is off the scale
Burned out rear turn signal filament...replace the bulb.
Old 02-16-2007, 05:58 AM
RazM's Avatar
Ok cool, what got me was the fast rate the blinker sound and front blinker were running at.
Old 02-16-2007, 06:29 AM
lamric's Avatar
Faster blink rate is because all the voltage drop is occuring over one turn signal lamp instead of two.
