Old 08-04-2005, 06:25 PM
Marc H3 Marc H3 is offline
Marc H3 is off the scale
<span class="ev_code_BLUE">I thought I would share my small issue with all of our H3 Members on here, just in case anyone else might be noticing a similar noise. I am experiencing a low sounding squeal from my fan belt on my H3.
It is most noticeable at cold engine start ups. Apparently when the assembly plant does it “fluid fills” sometimes there can be a slight spillage of coolant. If this fluid accidentally drips onto the fan belt it could cause a low squealing or chirping noise on cold start ups.
BTW: That issue has been corrected. I believe it only involves a very few early builds. </span>
