Old 07-13-2007, 12:31 AM
tomp's Avatar
tomp tomp is offline
Default I found a way to disable Traction Control when offroad!!!
Found out today that if you change your tire size to a very large tire size setting, using a handheld programmer, that it will disable traction control. Keep in mid that your speedo will not be accurate and you'll have an error on the dash until you put the settings back to where they should be.
This will come in handy sometimes
