Old 08-27-2007, 12:10 AM
trailerpup's Avatar
Default Front End Alignment
Might be the wrong part of the forum for this question, but.....
so I cranked my torsion bars to 24 1/4 inches. had it aligned. forgot the sheet of paper from Truxx lift kit with their alignment specs for 25 1/4 inches in front... and figured the alingnment guy would know what he was doing (I don't have the Truxx lift, just SAW t-bars and cranked, but i have the same ride height that you end up with using the leveling kit). any way the Truxx instructions say the alignment specs are supposed to be:
caster left: 1.5, caster right 2.0, camber left 0, camber right -1/4, toe in -1/32.
After my alignment they gave me a sheet of paper that says:
caster left 3.97, caster right 4.07, camber left .34, camber right -.01, toe left .15, toe right .08, toe total .23.
I don't know anything about alignment, but these numbers seem pretty different. what do you think? thanks.
Old 08-27-2007, 12:29 AM
RuggedH2's Avatar
RuggedH2 RuggedH2 is offline
Default Re: Front End Alignment
trailerpup, does it drive straight?
You're just gonna have to do it again after your next off road trashing anyway.
