Old 07-24-2007, 10:31 PM
BigBlueH2 BigBlueH2 is offline
BigBlueH2 is on a distinguished road
Default XM to Sirius....
I have an 06 with nav. I was wondering if I get the Sirius converter is that all I need will I need new antenna they claim I wont need new antenna with 03 and up GM models ? And will it work on the navigation come up list song artist etc. ?
Old 07-24-2007, 10:37 PM
Drainbamaged's Avatar
Drainbamaged Drainbamaged is offline
Drainbamaged is on a distinguished road
Default Re: XM to Sirius....
The stock headunit is xm ready so you will need a sirius to GM adaptor plus the sirius Tuner. It will come with an antenna that you will have to use. The stock antenna is used to pickup XM signal's only and it will not pickup sirius unless they have made an adaptor that I don't know about. The text info should show up on the stock headunit. Just make sure you get a good well known adaptor like Metra, DEI, etc....
Old 07-25-2007, 01:40 PM
md_sailor's Avatar
md_sailor is off the scale
I had the factory XM Box and swapped it out for a Sirius box. I simply took the Plastic fitting off of the end of the Factory XM antenna and plugged it into the Sirius box. The fitting was simply to lock the antenna to the unit it had nothing to do with making the signal connection, I have had no issues...Works flawlessly! Good Luck!
Old 09-23-2007, 02:26 PM
cage cage is offline
cage is on a distinguished road
(all info is specific to my '03 H2, Y91 option with in dash changer and without XM installed).
The kit I used is SIR-GM1
First, you must ensure that your factory head unit is Sattelite Ready- look at the front- if it has a BAND button (not AM/FM) then it is good to go.
If you have factory XM installed, you can indeed remove the clip and use the existing antenna. If not, use the one that comes with the kit. I ran my wire under the rail track, then inside by removing the passenger side clearance light, running under the wire grommet, and putting silicone around the edge. Then, the good ole Coat Hanger and string technique to route it (I pulled my pass side grab handle and gained access by a hole in the metal that would be above and toward the door, ref passenger sitting position).
If you have XM, drop the glove box and make the swap there. The kit has 2 harnesses, 1 for XM Installed at Factory, 1 for not. If you have factory XM then it is about a 10 minute install. If you do not...
Then it will be a couple hours. You must remove the center console in order to remove the front dash trim around the radio. Then remove 3 bolts and pull the radio. The sirius kit instructions show in detail what you need to do, but basically- plug and play. Route the wires, and you will need to splice into one 12V power source and a chassis ground for the noise filter. Then reassemble. I put the actual Sirius 'box' above the glove box with zip ties , deconflicted from the airbag.
Now when you cycle thru the 'bands' you get the standard AM, FMs, and SIR1, SIR2.
Cheers.
Old 09-24-2007, 04:51 AM
johndjmix1's Avatar
johndjmix1 johndjmix1 is offline
johndjmix1 is off the scale
You know i have been thinking about doing this too, but what about the meger???? Then it would have made the swap a waste.
--John
2006 Hummer H2 Lux Series
www.JohnHasMoreFun.com
1/4 Mile 15.29@91.34mph
Mods:
Warn 9.5 Winch
Old 09-27-2007, 01:33 AM
Programming is still supposed to remain different - as I understand.
