Old 07-05-2007, 12:35 PM
410225 410225 is offline
410225 is on a distinguished road
Default 12V socket not working
I am trying to plug in GPS on the front console 12V accessory socket and it seems there is no power. Cigarrette lighter works, no fuse blown, but the other two 12V socket does not seems have power. Where can I look elsewhere to find what the cause is?
Old 07-05-2007, 01:42 PM
Default Re: 12V socket not working
they may have not been plugged back in if the center console was taken apart for audio/video work or they may have a seperate fuse for those outlets. ill take a look.
Old 07-05-2007, 02:32 PM
Microday's Avatar
Microday Microday is offline
Microday is an unknown quantity at this point
Have you tried another accessory?
The sockets lengths will be different and you may not be getting the ground or postive fully engaged.
Also - The cigeratte socket will have a larger fuse (more amps) then the 12V sockets.
had '05 H2 SUT, LUX, Desert Sand
Had '05 Desert Sand H2 LUX
Had '05 Red Metallic H2 ADV
Old 07-05-2007, 03:33 PM
I have tried few different accessories to see if it work. None of them works on the front center console. Back ones (rear) are fine. I did check the fuse box inside the hood and looks nothing is burnt.
Old 10-07-2007, 10:09 PM
Shrek_H2 Shrek_H2 is offline
Shrek_H2 is off the scale
Did you figure out what was the problem? me the front ones are not working ...rear passenger one is working...and trunk is working ...no fuses burnt and eveyrthing is plugged in....
I was running a inverter with my xbox360 they all worked and then all of a sudden nothign and the one thats working seems like it doesnt have enough power to run the xbox360.
2003 Hummer H2
2000 BMW DINAN 5 (540i)
2002 HarleyDavidson V-Rod "FOR SALE"
All the great toys are on my driveway.....
Old 10-09-2007, 01:14 PM
I had a chance to pull out the center trim to install NAV unit and found the plug was not fully engaged. It is all fine now...
