01-05-2008, 03:00 AM
Which tire has the best ride, Pro Comp Extreme A/T, or Nitto Terra Grapplers?
I am wanting a good riding, quiet, and long lasting tire. Any opinions will be greatly appreciated!
Jimmy
01-05-2008, 04:26 AM
Re: Which tire has the best ride, Pro Comp Extreme A/T, or Nitto Terra Grapplers?
TOYO
01-05-2008, 04:54 AM
Go for the exteme a/t....they are quiet and balances out nicely...and dont look like sissy boy tires like the nitto terra grapplers. I ran the extreme a/t last go around but i wanted more aggressive tire so i switched to the Kumho m/t. The kumhos were very quiet at first but now there is no question the extreme a/ts are much quieter and i would say rival that of the stock bfg. They also performed as well as i could expect. In fact i may very well put them back on(they are in the garage)as they still have lots of mileage on them.
01-05-2008, 05:18 AM
I researched tires and read forums for weeks before I bought Toyo Open Country's. Everything I heard about Nitto's was either they were too noisy or wore down too fast, or both.
The Toyo's have been excellent, quiet and agressive looking, most importantly they perform great- mud, snow and daily driving. Their tread design cancels noise above 15 mph so you don't get that howling on the highway that's usually common with agressive tread patterns.
Do a search on Toyo's on this forum and you'll see what I mean.
01-05-2008, 09:49 AM
01-05-2008, 07:57 PM
IM sure you mean the Open Country M/T:
There is also the Open Country A/T which look very close to the sissy boy terra grapplers:
01-06-2008, 05:03 AM
That's correct- Open Country M/T
Damn! 68? here in Kansas today, I knew if I held out long enough the driveway would melt without shoveling
01-07-2008, 11:25 PM
Pro Comp Extreme A/T's are the way to go. there a very quiet tire and it goes anywhere with out a problem, they like water, sand, mud, rocks, & dirt from what i have driven, i have yet to drive on snow. they look like new with 17k miles on them. they are directional tires, so rotating them is only front to back and so on.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
