Old 01-15-2008, 04:43 AM
Rhyno's Avatar
Rhyno Rhyno is offline
Rhyno is off the scale
Default FABTECH Lift ?
I'm going to be getting the 6" Fabtech lift. I've got a 2006 with air ride, does anybody know if I will have problem with the rear air sensor?
Also what is the best backspacing if I run 40" tires?
Old 01-15-2008, 02:18 PM
Default Re: FABTECH Lift ?
i had a fabtech 6 inch lift with air ride on a 04 .. i had no problems.. but i seem to remmeber something about 06 and up sensors not being adjustable. but im sure their is a way to do it.
Old 01-15-2008, 11:43 PM
Rhyno's Avatar
Ya I can't seem to find a solid anwser if this lift will work on a 2006 with air ride! I have my heart set on this lift but if it doesn't work what would your guys second pic be?
Old 01-16-2008, 09:53 PM
datapimp69's Avatar
datapimp69 datapimp69 is offline
datapimp69 is on a distinguished road
there is 2 diffrent kits, one for spring and one for air.
make sure you order the right one.
Old 01-16-2008, 10:37 PM
Vettster Vettster is offline
What does Fabtech say?
Old 01-17-2008, 02:03 AM
Rhyno's Avatar
On Fabtech's site it says that it should work on a 2006 with air. On Trailduty.com it says Air Suspension - 03-05 Only but they probably havn't updated there site.
Old 01-17-2008, 03:09 AM
I don't know about you but when I shell out that much dough the words "should fit" are not in the equation. I would call Fabtech and see if they can give you a straight yes or no.
Old 01-17-2008, 04:21 PM
datapimp69's Avatar
as i said there are 2 part numbers, it dosent take but a sec to check.. from fabtech site
Old 01-18-2008, 01:31 AM
Rhyno's Avatar
I have been in contact with Fabtech via email and they have told me that their 6" lift will NOT work with my 2006 air ride SUT. The rear suspension on a air 06 SUT is different then past years so they are working on a fix right now.
Old 01-22-2008, 12:12 PM
H2 Doberman's Avatar
H2 Doberman H2 Doberman is offline
H2 Doberman is an unknown quantity at this point
Is ditching the air ride an option? You could just put the coil springs that come with the Fabtech kit on the truck. I'm not sure if this has been done before or not?
Old 01-22-2008, 05:32 PM
THey've been working on that "fix" for a while now. It's due to the non-adjustable air ride sensors.
Old 01-23-2008, 04:59 AM
ASTAR's Avatar
ASTAR ASTAR is offline
ASTAR is on a distinguished road
Mine worked fine. Had a different mounting bracket for the sensors that were slotted.
MINE - 2006 H2 SUT
