Old 09-30-2008, 02:05 PM
DoubleAction's Avatar
DoubleAction DoubleAction is offline
DoubleAction is on a distinguished road
Default Need help on fog lamps Please!!
Hi every one i got confused with what i know and what i got from the manual came with my PIAA 520 ATP lamps ....
So can some one help me with installing the wires in a proper and profecinal way for my H3 & using the GM indash switch to power up the PIAA lamps.
Thank You in advanced..
- HUMMER H3 Lux/Pkg (Boulder Gray) 2006
- Audi Q7 (White) 2009
Old 09-30-2008, 04:27 PM
Default Re: Need help on fog lamps Please!!
There are a few ways to do it as far as selection of power leads among other choices. You can use the search pull down for lots of info on the lights topic. You will have to pull off your panel which is detailed in one of the threads. Once you have that off you can install your switches and connect and solder your wires up...
The aux power lead that hangs down on the drivers side will get you to your relay from your kit...
Probably a good Saturday project with lots of breaks for checking your progress on line!
Good luck!
Old 09-30-2008, 09:09 PM
Good luck!
THANKS SO MUCH FOR YOUR INFO
Old 10-01-2008, 01:46 AM
What word is this, I can't find it on the internet...
Old 10-01-2008, 03:00 PM
Bad spelling on ((professional))...
Any way i asked for help on installing my fog lamps not helping me in spelling
SO IF YOU CANT HELP dont waste our time reading your topic...
