View Poll Results: If a Cast Iron Front Diff with E-Locker were available for your H3
Run to Mr. Goodwrench and have him install one for you
5 |
31.25% |
Go to the parts desk, buy one, and install it yourself
8 |
50.00% |
forget it, I dont need it
3 |
18.75% |
10-15-2008, 12:34 AM
H3T Cast Iron Front Diff with E-locker
If available for your H3 would you
HURF
Restored \'82 Jeep CJ7 ,258,.40 over,,Comp Cam,,GM HEI,,Borla Header,,Weber 38,,T5,,D300,,D30,,4:56,,Detroit,,AMC20,,trussed,, Detroit,,Warn full floater,,trXus 33X12.5X15
Hummer Test Driver
10-15-2008, 04:16 PM
Re: H3T Cast Iron Front Diff with E-locker
I hope they do.
It should be a complete kit with the housing and diff/locker pre assembled, with wiring, dash switches etc.
Plug and Play!!
Just bolt on the CV joints and plug in a few wires and you would be good to go!
Maybe someone can come up with a parts list/$$ to do the swap?
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
10-16-2008, 04:47 AM
...I'm in the process now with this. I'll have the info in teh next two weeks or so. GM parts and accesory division is looking into making this an accesory. The mechanical part is easy. The wiring is under review. I should ahve warranty info as well. ..and there is a core charge.
You would get a complete diff replacement. It's cheaper than to have someone take your aprt, drill for the wiring and than put it all back together sealing it properly. So the part number that I hope to have soon will be for a new diff with core part #, dash panel, module, wiring harness., and warranty info..oh yeah, cost too. I expect about 2K with labor. I'm hoping for $1500 to $1800 out the door with full warranty though.
...to be clear, this info is second hand, but from what I consider, a reliable source.
10-16-2008, 06:17 AM
for a few hundred in labor, one would void their warrantee? Hmmmm
10-16-2008, 04:09 PM
If the dealer can do it for $1500-1800 and warrenty I would go for that
Desert Dan
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
