Old 11-18-2008, 01:21 AM
nahanee20 nahanee20 is offline
nahanee20 is on a distinguished road
Default Tire Pressure
on 35" toyo M/Ts what should the tire pressure be to give the best ride. i have 20" rims if that matters. thanks for the help.
Old 11-18-2008, 03:40 PM
HummerMann's Avatar
Default Re: Tire Pressure
I run the 33" Toyo M/Ts on 18 inch rims and have been very pleased with all around performance running them at 30 psi. It's a good ride @ 30 psi on the road and they wear pretty well at that setting.
Hummer, like nothing else
Old 11-18-2008, 05:50 PM
rrboy rrboy is offline
rrboy is off the scale
I have the very same set up as you...35x12.50 20 on my hummer h2 sut for about 3 1/2 yrs now...The first 2 years or so I was letting the dealer I bought them at do the airpressure on them and they were airing up to 50psi. They seemed to run very good at that, very good wear. But I got to thinking about the air pressure the h2 calls for which is 37 psi, so about a 1 1/2 yrs ago I aired down to 37 and have been running at that ever since. It makes the ride alot more forgiving, softer so to speak. Very good traction and even the wear is even. I have about 35k on the tires now and I would say I am about 40% left, so I am very happy with the longevity of the tire also. I must say they take a massive amount of abuse, I do alot of hunting on rocky roads and have never had a leak yet, I will diffently buy again when these wear out. So I in my experience, the lesser the pressure the softer the ride, only draw back is if you ever gonna haul something heavy, just have to air up to compensate for the load.
Old 11-19-2008, 02:29 AM
thanks, im gonna air them down to 40.
Old 11-19-2008, 04:45 PM
Thumbs up Re: Tire Pressure
I am running 37x12.50x17 pro comp extreme a/t's at 42psi and the ride is fine and so is the wear.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
