Old 10-19-2008, 05:21 PM
Shawndondo Shawndondo is offline
Shawndondo is on a distinguished road
Post suspension Question
As i was walking to my H3 the other day it looked like it was leaning to one side. I just thought it was the parking lot, when I went home and parked it in the drive way i took some measurements and yep it sits crooked....i measured 39 inches on the rear driver side (from ground to fender lip) and 40 inches on the passenger side. Also measured from the top of the axle to the bump stop and still an inch different....?
Does the gas tank affect the suspension that much I would think that the suspension wouldn?t sag that much....but hey no engineer.. If anyone has some input please let me know. thanks
Old 10-19-2008, 09:11 PM
danielf danielf is offline
danielf is on a distinguished road
Default Re: suspension Question
no. tbars. crank em. mine was the same way. when i decided to level it i cranked the bars and had to crank more on the driver side. i think they all have a little sag right off the lot. you might want to check but i think a handful of people will tell you the same.
Old 10-19-2008, 09:25 PM
use the SEARCH function !!! there is lots to read there...
Old 10-19-2008, 09:37 PM
Like RYD said Depends! He may wear em!
Old 10-20-2008, 04:19 AM
thanks yeah i did a search after i posted the question...jumped the gun i guess..lol!
gonna bring mine to the dealership since i only have 2500 miles on it..should i bring my louieville or are the dealerships aware of this problem and willing to fix under warranty? thanks
Old 10-20-2008, 01:03 PM
sometimes a bottle of wine to your regular service writer helps but should be warrenty...
every year I give something different to my service writer...i'm treated like a king...!
Old 10-21-2008, 12:42 AM
thanks for all the help! went to the dealership today..no problems tweaked my tbars aligned everything. the only thing they wouldnt do is crank the tbars so the front is level with the rear.. oh well.. thanks again yall
Old 10-21-2008, 12:55 AM
H3slate's Avatar
H3slate H3slate is offline
Glad you got it fixed. My dealer is the same way, they will not mess with the suspension outside of spec. Of course there are dealers that will gladly take your business and adjust your torsion bars for you. I just did it myself and got a front end alignment.
The Bilstein shocks and extended bumpstops from Trail Duty are a must if you do crank your t-bars.
