Old 10-30-2008, 01:09 AM
HummerJim's Avatar
Default Sunroof Wind Deflector Buzz
I found that when I run 70 mph with my H2 into a 25 mph or greater headwind (95 mph of wind over the deflector) the factory air deflector on the sunroof buzzes and vibrates loudly against the roof. Has anyone else had this problem and is there a fix?
Old 10-30-2008, 01:31 AM
Default Re: Sunroof Wind Deflector Buzz
Have you checked the side pillar plastic trim? It's a known defect that they get loose and you'd swear the sound was coming from the sunroof deflector.
Check your side trim pieces... 10 bucks says the two sided tape let loose.
Mark
Old 10-30-2008, 02:53 PM
brad_p's Avatar
brad_p brad_p is offline
Yeh i was in the same boat, i always thought it was the roof aswell but its not its those damn pillar i gorilla glued mine. Time for a new windsheild i cracked mine putting my 11 foot stand up paddleboard in my hummer, yes it did fit but i didnt have it in there right and when i closed the rear hatch it pushed it into the windsheild.
----------o-o-o-o-
[[_]|[]|[][___]
[---\-|-----[ -OIIIIIIIO-]
"(O) ) ---- (O) )/"H2"\) )
Old 10-30-2008, 10:41 PM
HummerJim's Avatar
Is that the almost vertical black plastic piece by the front windshield pillar (2 ft. long)?
Old 10-30-2008, 11:07 PM
o2man98 o2man98 is offline
o2man98 is on a distinguished road
Does anyone have a pic of the section that you refastened? Mine seem secure but I get the "sunroof" buzz.
2007 H2 SUV All-Terrain Blue - His
2008 H3 Alpha Graphite Metallic - Hers
Old 10-31-2008, 12:21 AM
HUMMERICH23's Avatar
HUMMERICH23 HUMMERICH23 is offline
HUMMERICH23 is on a distinguished road
Yeah mine does it too and drives me insane and does it at way lower speeds like 25+ when it is wet or has rained and residual water is in a crack or somewhere, Absolutely drives me nutts. I thought it was the trimming around the sun visor too. Can someone post a pic of which piece than makes the noise?
Rich
Old 10-31-2008, 12:43 AM
H2Finally's Avatar
Yup, the 2 black plastic trims on the sides of the windshield. One screw is hidden behind the rubber door trim, the other I think you need to pop your fake air cover to access.
Either double sided tape, RTV silicone, or the black mastic that mirror guys use will cure the buzz.
Leaking is prob something else. Most common culprit are blocked sunroof drain holes (if you have sunroof), and the front marker lights (use black RTV silicone).
Can BLING Get You Home?
Old 10-31-2008, 02:25 AM
HummerMann's Avatar
My H2 just started doing that this summer at about 75 mph, and I thought it was the sunroof wind deflector too. This summer I had the windshield replaced and apparently the didn't tack down those pieces. I've been trying everything, including pieces of rubber under the sunroof air deflector. Tonight I took off the plastic windshield trim pieces, glued them down with mastic, did a high speed 90 mph highway run and voila - NO NOISE ANYMORE - THANK YOU THANK YOU THANK YOU!
Before I read this post I would have sworn it was the sunroof deflector.
Hummer, like nothing else
Old 11-03-2008, 02:54 AM
Decade Decade is offline
Decade is on a distinguished road
My H2 just started doing the same thing. After reading this thread, I went and checked the trim pieces....mine were secured. Figured I better check the sunroof deflector. Sure enough, one corner was loose. I used weather stripping adhesive to glue it back down...no problems since.
Old 11-03-2008, 10:41 PM
h2newfie h2newfie is offline
h2newfie is on a distinguished road
Thanks for the info as our H2 makes the same noise when we are driving a certain speed. We are looking into these suggestions. Thanks all.
