Old 10-11-2008, 06:48 PM
johndjmix1's Avatar
johndjmix1 johndjmix1 is offline
johndjmix1 is off the scale
Default Easyest way to deflate air bags???
Can someone give me a simple way to deflate the air bags.....i have my hummer in my trailer and the roof is really close to contacting the lift above it.
I could pull the lines off the top but theres GOT to be a simpler way than that?
What about connecting the inflator and letting ti drain then somehow triggering the valve?
--John
2006 Hummer H2 Lux Series
www.JohnHasMoreFun.com
1/4 Mile 15.29@91.34mph
Mods:
Warn 9.5 Winch
Old 10-11-2008, 08:24 PM
o2man98 o2man98 is offline
o2man98 is on a distinguished road
Default Re: Easyest way to deflate air bags???
2007 H2 SUV All-Terrain Blue - His
2008 H3 Alpha Graphite Metallic - Hers
Old 10-23-2008, 09:04 PM
HumminNBoatin''s Avatar
deflate the tires
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 11-16-2008, 12:02 AM
Dug Dug is offline
Dug is off the scale
Good question. My **** box deflates everytime its shut off.
I wonder if you could trick it into dumping the air by moving the lever in front of the rear tires. Maybe you could disconnect the rod hooked to it and move the lever all the way forward, thus dumping the air. Good luck.
Old 11-18-2008, 08:11 PM
johndjmix1's Avatar
Tried that, disconnected the sensor rods from the suspension arms and maxed them out.....got "Air suspension Error" or somthing to that effect on the display.
You would think there would be a simple way to do this.
--John
Mods:
Warn 9.5 Winch
Old 11-18-2008, 08:25 PM
IRA51's Avatar
IRA51 IRA51 is offline
easyst way to get clearance is to remove the 2 cross bars on the roof rack .
A government big enough to
you have.
-- Thomas Jefferson
