Old 02-08-2006, 11:55 PM
Arob Arob is offline
Arob is off the scale
Does anyone know a website that sells snorkel kits?
Old 02-09-2006, 12:28 AM
tomp's Avatar
tomp tomp is offline
While military Humvees have a snorkel kit extending the exhaust and air intake to roof level, making it possible to operate in 60 inches of water, Civilian Hummers cannot use the snorkel kit because the dash, fuses, alternator, power steering cap, transmission controller, radio, and engine controller are not waterproof.
Old 02-09-2006, 03:06 AM
Efrain's Avatar
Efrain Efrain is offline
Efrain is off the scale
I've seen snorkel kits on jeeps,
how does that work?
Old 02-09-2006, 04:13 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Efrain:
how does that work? </div></BLOCKQUOTE>Posing.
Old 02-09-2006, 12:35 PM
Thanks for the explination, i knew there had to be a reason why i had never seen them for sale on any of the websites i have been to.
Old 02-09-2006, 12:54 PM
Ernie Italy is off the scale
..and close the passenger side intake..
but the problem is to mantain the same size of the tube of intake without pressure problem (I hope you understand).
Old 02-09-2006, 01:33 PM
And goes out with a snorkel safari as Range Rover or a tube as H1 ?
Old 02-09-2006, 01:50 PM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
I wouldn't even consider adding a snorkel unless it was absolutely necessary. It would affect you overall performance, and would give yourself a false sense of waterproofness(Is that a word?). Unless you would go through the pains of waterproofing all of your electrical components, and extended all of the breather lines above snorkel height, I wouldn't do it.
As far as performance, think of it this way, would you run a marathon breathing through a straw?
That's about what you would be doing to your engine! So, think before you leap on this one!
IMO
Ric-H0
www.meatspin.com
