Old 03-23-2009, 06:08 PM
r-cman's Avatar
r-cman r-cman is offline
r-cman is on a distinguished road
Thumbs up Predator Raptorq?
Does anyone have this computer upgrade? It has some pretty impressive numbers!
Increase the performance of your H2 with an additional 64 hp and 79 ft/lbs of torque! Hands down the most performance available for your money. With the RapTorq H2 Computer, we adjust your speed limiter, rev limiter for a broader power band, shift points, and increse shift pressure for quicker firmer and more precise shifts. Easily installs in minutes with no computer skills. Comes with a limited lifetime warranty and a full 30 day money back guarantee. This is a core exchange item, a $500 core charge applies upon shipment. Return your stock core for a full refund within 30 days. Available for all year 6.0L H2's as well as the new 6.2L 2008 model.
Old 03-23-2009, 06:53 PM
Lean Machine's Avatar
Lean Machine Lean Machine is offline
Lean Machine is off the scale
Default Re: Predator Raptorq?
I installed one of these units about a year ago on my 2005 H2. You will notice a difference. Basically your rig will stay in 1st, 2nd, etc. gear longer under normal driving conditions giving you a little better acceleration.
\'05 H2 Lux Pewter SUV, Nav, Air, Sunroof, 22x10 E Forged EF16 with BFG Limited Edition Mud-Terrain T/A 335/55R22 and varies Chrome Parts
\'08 H2 Lux White SUT with Sedona interior - SOLD
\'08 H2 Lux White SUT with Sedona interior and 6'' Fabtech Lift
Old 03-24-2009, 01:52 AM
[__--MUD--__]'s Avatar
Your paying for the exact same computer in the truck already...save your money and find a competent tuner locally. You should find custom tune in the $300 range w/ free updates as your needs chage.
I know this guy does alot of mail order tuning and sponsors a number of forums.
http://gowheatley.com/home.html
Check out http://www.performancetrucks.net they have a pretty damn big tuning and diag area.
Old 03-24-2009, 02:01 AM
The problem is finding a tuner with a dyno that will handle 4 wheel drive.
And if you do find one, I assure you won't get it dyno tuned for that kind of money.
As far as this wheatley guy, the problem with those tunes is that they are a canned tune, usually fairly generic and usually at least 25RWHP less than a tune on a dyno or by laptop.
When I supercharged my last H2, I had Nelson Performance do a tune. It was basically the same thing... you gave him specs, he programmed your computer. Obviously without a dyno or laptop, he's doing the same thing... a canned, generic tune.
I'd love to find someone that would tune my ECM via laptop. Then you'd get real world readings.
The problem even with dyno tuners is they tune the car at WOT throttle in 3 or 4th gear.
Though they can change fuel tables, timing, etc, etc, there is usually a slight driveability that is missed while tuning on a dyno as opposed to a laptop tuner riding down the street with you.
My .02 worth.
Mark
Old 03-24-2009, 06:40 AM
Mark
Allen last year or maybe year before put in a dyno plus just down the road he also used a dyno from another friends company to build his tunes. He does push to get safely what you request.
You can tune without a dyno and using a laptop plus just my opinion get real world tunes. It takes more time but, you hook up laptop and run down the street as well as interstate in scan mode then make flash to ecm. My onboard computer setup that takes over all A/V navigation etc. type functions will be set to boot up in scan mode everytime you get in to go. You can verify it's startup then on touch screen tap to switch to A/V screen control etc. while your tuning software scans for you to check. If you see a change needed stop make flash on the spot. This is intensive but, any local tuner that has software can spend a few hours running real time scan runs and get a very good tune.
But, Allen is the best alternative.
TAZ
Old 03-27-2009, 07:04 PM
Brianb231 Brianb231 is offline
Brianb231 is on a distinguished road
will these types of tunes make extended warranty coverage invalid????
Regards,
Old 03-28-2009, 05:00 AM
In all honesty it depends on your dealer. My dealer told me to do what I wanted and they would back me. They wanted to see what could be done woth an H2. So it would not hurt to ask but, if you know how they feel use a handheld so you can put stock tune back in anytime you go for service.
TAZ
