Old 03-28-2009, 09:09 PM
03h2gm 03h2gm is offline
03h2gm is on a distinguished road
Default dashboard info center problem
help pls, dashboard infomation center keep changing language and either one of the button woks to control it.
Old 03-29-2009, 01:56 PM
HummerMann's Avatar
Default Re: dashboard info center problem
Once you select a language in should lock out the others. Disconnect then reconnect your battery, then select the language you want. There was an aftermarket black box (actually it was light blue) sold around '04 that gave you more languages (search the threads if you think you have one of those).
Hummer, like nothing else
Old 04-04-2009, 07:29 PM
ill try it today , thanks
