Old 04-18-2009, 08:34 PM
todd5 todd5 is offline
todd5 is on a distinguished road
Default broken speedometer and air vents
hopefully someone can please help w these issues. my speedometer is broken and the needle sits at 60 or above if it does move it will only jump up to 10 or20 mph. the needle never goes back down to 0. also my driver side vents shot out hot air when i have the air conditioning on and cold air when the heat is on. all of the other vents work correctly.
Old 04-18-2009, 10:27 PM
Default Re: broken speedometer and air vents
issue 1: you need an entire cluster replacment through your dealer. If you're out of warranty, pull your cluster out yourself and take it to them. They will send it out for replacment. you can use a programmer or GPS for the week if you need to drive the truck still
issue 2: This issue has been going on since 03's came out. It happened on one of mine and they replaced the entire unit in teh dash....
The climate control module may have to be re-programmed. The dealer can start there. If you are out of warranty, try disconnecting your battery for 10 minutes or so and see if it will reset on it's own.
If that reprogram doesn;t work they have to replace the CCM or fix/replace the blend door actuators...if they have to do the actuators, you're looks at a large bill as it's an all day job. Both teh actuators and the CCM's go out in tehse trucks.
good luck.
Old 04-19-2009, 07:48 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Check with your dealer, there is a special policy on clusters in trucks and latley i have seen a few hummer ones covered as well. Worth looking into if its free.
1998 Chev Z71
2007 Chev Trailblazer SS
