Old 07-31-2011, 09:09 PM
Easy Ed Easy Ed is offline
Default Front Drivers Diff Seal
I know it has been discussed before on the replacement of the seal and am in the process of replacing mine due to a leak. I am at the point of buying/ordering one (not today cause it is Sunday, duh) on line or from a parts store but have a question for those who have done it before, is the replacement seal the same as the one you took out. The reason I ask is a lot of the ones I see on line do not look like the one I took out This one has many sealing surfaces and what I have seen on line just looked like a lip seal type
The one taken out has the following info on it
Air Side ????? WTF
SABO 7663 14
AAM 40014744
Made in Brazil
I do know the manufacture is SABO and it is a 1.625 ID (41.275 mm) with a 61 mm (2.4015) OD and 14 mm (.5511) wide.
Going to see if I can find any info on SABO but if those of you who have changed theirs before could let me know if what went back in was the same as came out would ease my fear of getting a wrong seal.
Thanks much, Ed
Looks like it has been replaced with 19169124 from 12479155.
9.25 IFS front axle listed here (it is a .pdf download from AAM)
http://www.aam.com/file.php/255/axle+shaft+brochure.pdf
Old 08-01-2011, 10:50 PM
Default Re: Front Drivers Diff Seal
Local NAPA had a SKF 16123 as a direct replacement for the OEM number of 19169124. Seal is in the diff and am hoping the leak is gone.
Ed
