Old 03-05-2010, 06:48 PM
RapaNuiMan RapaNuiMan is offline
RapaNuiMan is off the scale
Default Window Motor Cable Problem
I rolled the passenger window down and when I rolled it up... clunk noise... and it stopped working. Now it kind of rolls up half way but has to be forced manually all the way up. I removed the door panel and it looks like the motor cable is loose/whacked. The botton cable guide/tube seems to be detached. Any ideas?
Old 03-07-2010, 12:40 AM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: Window Motor Cable Problem
YOUR REGULATOR Is DONE. sometimes you can repair them ,but I would just replace it .
A government big enough to
you have.
-- Thomas Jefferson
Old 03-07-2010, 04:01 AM
h2003 h2003 is offline
h2003 is on a distinguished road
yeah.you need a window regulator it comes with the window guides pulleys and cables all set up you just need to bolt it in.
