04-04-2010, 09:01 PM
completed my ride....
Well here`s the poor mans way to modifiy my 2003:I first started by replacing the outside mirrors with ones from a 2006...so now they fold.Replaced the air cleaner with an Airaid cleaner only,no cold intake.Bought a leveling kit piece by piece starting with Skyjacker Nitro 8000 shocks,I bought the "green" keys and 2" rear coil spring adapters.Which i got a total 4inch lift.I came across a great deal on 4 37x13.5-17`s toyo MT open country tires... get this, for FREE I traded my 35`s for them.
04-04-2010, 09:12 PM
Re: completed my ride....
You should be proud of it in this day and age if you can do it yourself and save some money more power to you.
Do you have any before and after pictures of it?
~Richard
04-04-2010, 10:20 PM
pre lift/tires
04-04-2010, 10:26 PM
after
04-05-2010, 01:03 AM
Hummin in my front yard.
04-05-2010, 01:15 AM
Looks really nice and clean too.
Almost need to get it dirty.
~Richard
04-05-2010, 09:48 AM
Do you have a pic or part number to the coil spring adapters? I am switching from airbags to coils soon. I ordered FABTECH 6" lift coils, but would like to get a bit more rear end lift.
thanks
2003 H2, 408 CI, K1 Forged 4" stroke crank, K1 6.125" forged rods, Wiseco X-Series 0.30 forged pistons, Schneider cam, FAST 102mm LSXRT, precision flow injectors, Comp Pro Magnum rockers, SA Gear DR timing set, ARP main studs, 90mm ETC TB, Airaid MIT, MSD Coils/wires, Dynatech Headers/high flow cats, Magnaflow, Jessie James Black Widows 20x9, Nitto Dune Grapplers 37", Fabtech 6" lift, CK Performance XHD 4l70e and 4.56 Gears
04-05-2010, 09:07 PM
I got the coil spring adapters from ebay.they`re 2" aluminum spacers.company called McBay performance,cost $53.00.No phone # or email address.Hope this helps alittle..
04-06-2010, 01:58 AM
Looking good man. I like that brush guard!
Tell me more about your shocks!?!?
04-06-2010, 08:34 PM
It is a great looking brush guard isn`t it....thanks again Eric.The shocks are skyjacker nitro 8000`s.I got the fronts from rockymountain 4x4 for $33,the rear from Skyjacker.com as scratch n dent for $25.Not a bad deal.
04-06-2010, 08:45 PM
Looks good! Spray down the chassis with some oil to slow up the rusting
