Old 05-19-2010, 05:01 PM
kazarw kazarw is offline
kazarw is off the scale
Question H2 brake bleeding/flush
Has anyone bled their brakes? and if so does the abs need to be bled at the same time or do you need a ECU controller to do so? I want to change the fluid but not affect ABS operation.
Can the calipers be bled via a vacuum pump or conventionally by pumping the brake pedal? anyone have any advice here?
