06-22-2010, 10:50 PM
h2 front leveling kits
Have been a member for a little while but new to asking questions, having trouble finding the best way to level out my 04 H2, can someone direct me to the best and safest method in order to maintain the factory ride, how much does it need to come up to level it off, should I use an ebay kit or GM items and buy longer front shocks, which shocks part number and how long if I go that way, or just use the ebay kits with shock extenders. Thanks for your help.
06-22-2010, 11:26 PM
Re: h2 front leveling kits
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
06-23-2010, 04:58 AM
Why not just torque the bars up? It says so right on the frame you need to adjust them with time up to 4in. Please school me if I'm wrong.
Missing the times when things where made to last.
06-23-2010, 09:54 PM
There is a current thread running here that deals with this question...
http://www.elcovaforums.com/forums/s...ad.php?t=39518
Thanks,
Mike
Mike
2000 HUMMER HMCS, kevlar flat black, Rubber Duck lift, Predator stage 3 kit, Predator (Wilwood) Big Brake kit, a work in progress...
2008 H2, graystone, air suspension (DELETED), U-steps, SMA brushguard w/valance (DRLs replaced by PIAA 520s), black taillight guards/locking fuel door/roof crossbars (x4), Cognito UCA/pitman-idler, Bilstein shocks, Rancho steering stabilizer, Kryptonite tie rods, green keys, Fuel D525 20" Revolver, 37" Nitto Ridge Grappler
06-23-2010, 09:58 PM
Just cranking the torque bars will put the ball joints of the upper control arms in an incorrect position/angle and speed their wear. The leveling kits available, such as the UCAK00001 from Cognito, rectify this issue.
Please see the above post for a link to a running thread that deals with steering upgrades but also touches on the parts needed to really beef-up the front end suspension and steering while leveling out the factory rake.
Mike
06-25-2010, 05:09 AM
If the truck came out of the factory at a set height and it sagged with time and use offsetting the joints up, cranking the bars will put the ball joints BACK down in the correct (out of the factory) position. No?
Still just talking...
I'm justifying keeping this thread a life as maintenance one, not upgrades like the other one.
06-26-2010, 04:12 AM
I have the truxxxx kit. Worked very week and was easy to install. Leveled the rig right up.
Michael
___________________
2005 White H2 lux
2005 Dodge 1500 Hemi Crew Cab
2007 Tahoe (Flex Fuel)
07-19-2010, 10:29 PM
I found that when I torqued up the bars using Truxx keys that the ride got bad...speed bumps were awlful. The Cognito kit with the new upper control arms put the ride right back to the stock feel.
CNTRY
DTOM
