01-09-2009, 06:50 AM
hummer shut off on wife onroad
My wife's H2 shut off while she was driving she thought it ran out of gas because she was on E so I came and put gas into the tank and I turned the key nothing happened and I replaced the battery and the starter and still doing the same thing......checked all of the fuse's and still nothing........can someone help me with this issue.
01-09-2009, 06:54 AM
Re: hummer shut off on wife onroad
I need a way to start the SUV so that I can get the SVU fixed. is this an Onstar problem? let me know.....
01-09-2009, 08:14 AM
Get it towed to the dealer.
01-09-2009, 01:59 PM
We just called onstar yesterday. You should still have your onstar card when you first signed up. There is a number on the back, I believe. You can call them and give your info and I think they will tow it. That's what you pay for. I just remember using for the H3. I limped to a spot where I had reception and made the call to onstar, and they came and towed my vehicle away to the dealership.
01-09-2009, 03:13 PM
If you could take the key out, it's not the battery. I'm not sure about all years of H2s, but when the battery is dead you can't take the key out on mine. Stopping suddenly then not cranking sounds definitely electrical - call Onstar have it taken to the dealer!
01-09-2009, 08:44 PM
What happens when you turn the key on? Does the ignition and accessory stuff power up like the radio and A/C or not?
01-09-2009, 11:50 PM
Take out your owners manual. You don't even need onstar if your service is expired. Your truck came with 5 years of Hummer roadside assistance. The numbers in the manual. They will tow you to the nearest dealership for free.
01-10-2009, 12:09 AM
I say Fuel pump went out or clogged up. Happens sometimes when it gets low like that. Pretty $$ to fix if you are out of warranty. Go buy one, and then look under the carpet in the back above the gas tank. If so, pop it off and get to work.
01-10-2009, 01:31 AM
Does the engine crank, if not check the crank fuse. Have you had an ignition switch replaced in the past, if you have sometimes the connector at the switch is broken and backs out. remove the plastic steering column cover(lower half) check the connector. While your there you can check for power on i think the pink wire with the key in the run position. Have someone attempt to crank the engine and see if the starter relay in the underhood fuse block clicks, if not your not getting power to the relay or the relay can be bad
01-10-2009, 01:38 AM
Thxs for all the Information guys! I was told it may be the egnition switch I will look at my options 1st because I live 58 miles from the nearest dealer.
If I turn the key over I get nothing but all powers is on and I think its not getting power from the egnition switch to the starter.........I was late on my payment my wife and I are Realtors and we were dry on closings for a while and now we think the creditors could have shut us down but we have 2 closing on monday I will pay the bill and after that I will determine then whats next.
01-10-2009, 01:43 AM
thanks I wil try that in the morn I have a frind that just came down from Novi micihigan and he worked at Novi Hummer for a while He told me to get all the info from you guys and print it out and he will read and scan over everything.
and try to fix it. also no crank when I try to turn the key........but all power is on.
You can pull the starter relay out and with the key on use a jumper wire to engage the starter across terminals 87 and 30 if i remember correctly, if it cranks the problem is somewhere between the ign switch and the underhood fuse block
01-10-2009, 01:50 AM
OK I will try the Jumper wire if this does not work! I guess I have to keep checking for problems.
01-10-2009, 01:51 AM
Heres the starting schematic for ya
01-10-2009, 01:57 AM
H-Tech thats Awsome...........I will look at this and print it out....this is great thank you so so so much.
01-10-2009, 02:00 AM
No problem, let me know how it works out
01-10-2009, 02:08 AM
10-4 will do.....
01-10-2009, 11:04 PM
that happen to my 03 a few years back.. Had it towed and ended up being some CHIP problem.
02-12-2009, 05:44 PM
Can you tell me how do I take the streering wheel off so I can chang out the casing for the egnition switch.....and do I need a special tool to enter the small pin holes on both sides.
