Old 05-18-2009, 09:55 PM
Hellz Hellz is offline
Default broken header bolt
SO Sat morning i starting my 03' H2 up, and got the loud ticking exhaust leak sound. pretty much knew right away what was going on. popped the hood and counted the bolt heads.. sure enough 1 was gone.
03 H2 bought about 3 months ago w/ 68k miles. got it for 19.5k out the door with 1 year/12k mile warranty on it.
got a appt with the dealership ( chrysler dealership) to have them fix the issue. so hopefully no surprises.
think i will have them check the air ride bags and the front wheel bearings while it is in.
anyways, this was just more of a whats going on post than a i need help post.
thanks
Old 05-19-2009, 12:06 AM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: broken header bolt
haveing a 03 fixed at the dealer ? all it is is a 6.0 chevy engine . did you check and see if it didn't just vibrate out and fall off ? if so you buy a new bolt and screw it in and you might be done . most any shop can fix a loose exaust manifold or header at less than half the cost of the Hummer dealer .
A government big enough to
you have.
-- Thomas Jefferson
Old 05-19-2009, 12:53 AM
it is the dealership i bought the H2 from.
as long as i go to the dealership i purchased it from, i dont have to pay the deductable on the extended warranty service.
the bolt broke off just a little under flush of the header. so no way i was going to get some vice grips on it without pulling the whole header off.
If i was going to do that, i might as well throw on some aftermarket headers.
ill give these guys a shot before i go somewhere else. if they can handle this simple thing, then ill keep going back. worst case, i take it to a chevy dealership and pay the $50 deduct.
Old 05-19-2009, 01:25 AM
HummBob's Avatar
HummBob HummBob is offline
According to my delaer, this bolts breaking is an ALL TOO COMMON thing!!!
I had JBA Headers installed last week and my delaer showed me one of my bolts that was busted......
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 09-04-2010, 03:16 PM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
If it were me I would look at ARP Bolts made for headers with the locking rings. I owned a Super Gasser and always used the products.
http://www.arp-bolts.com/
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
Old 09-14-2010, 02:12 PM
RJ03 RJ03 is offline
RJ03 is on a distinguished road
Hi Guys, I just noticed I have at least three broken. I'm planning on replacing all with new gaskets. I have a couple of questions, what should the new bolts be torqued to? Should I use any Antiseeze or Locktitie on the threads? And last but not least, should the engine be cold, warm, or hot in order to remove the bolts the easiest? Thanks for your help, RJ03
Old 09-15-2010, 12:51 AM
alpha alpha is offline
alpha is off the scale
I have had mine done 2x by the dealer already in my 03 H2. Covered under extended warranty to 100K miles - 72K on it now... Dealer says it's a very common issue...
Old 09-16-2010, 06:18 AM
vetteSUT's Avatar
vetteSUT vetteSUT is offline
vetteSUT is on a distinguished road
header bolts breaking is a common thing? That's the first time I've ever heard that for a vehicle... usually if someone overcranks and puts too much torque on one. Just weird how it just randomly happened. You gotta remember that if you buy stainless header bolts, they are weaker than plain steel.
