Old 03-11-2013, 08:07 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Default Delta Fog lights vs. Driving lights
I'm tired of my nasty OEM DRL housings, half the reflector is burned away at the top. The LED towers I installed makes them look 1,000 times better but I want something that looks even better.
I plan to buy the non-HID Delta set and eventually retrofit in some HID's like PDX did.
However here are my questions:
-what is the difference between the fog light and driving light sets? I thought I read somewhere around here the driving lights are fluted glass while the fogs are smooth??
-do these lights directly install into the factor mounting holes or is there modification requred to the back of the bumper?
-says it comes with a stand alone harness and relay kit. So do these plug into the factory harness at all or is there cutting and splicing required??
-Fogs show an H3 bulb for the light source, is that the same for the driving lights?
That being said I don't mind modifying or doing electrical work obviously if you've seen my build thread. At the same time I like to keep the electrical as close to stock as possible in regards to the plugs, etc in case I ever want to reverse the mods.
Basically I want the Deltas to function exactly like the factory DRL's we have (with the DRL mod most of us have).
Thanks in advance, and pics if you've got'em!!
