Old 10-23-2010, 10:19 PM
EastTexan EastTexan is offline
EastTexan is on a distinguished road
Lightbulb Stock Hummer H2 Off Road Lamp Hardware
I have a pair of OEM HUMMER H2 round off road lamps with NO hardware. I also have the OEM brackets to mount the lamps to my OEM brush guard.
I need the U-shaped brackets and hardware that attach to the the lamp body.
I tried using brackets off a cheap pair of lamps I had laying around, but they do not really hold the HUMMER lamps securely.
The HUMMER lamps have some "teeth" inside the bolt channel, presumaby as detents to hold the aiming position more securely.
Do any of y'all have an old, even damaged pair of OEM H2 round lamps or just the lamp brackets available? Or do you know a different brand of lamp that has the same style lamp brackets/hardware? Any other ideas? Thanks.
