Old 11-27-2010, 06:06 AM
pat123's Avatar
pat123 pat123 is offline
pat123 is on a distinguished road
Wink Steering Wheel Lights
Can anyone tell me how to change the light bulbs on my steering wheel, I have several that are burned out. Thanks in advance.
Old 11-27-2010, 07:05 AM
Default Re: Steering Wheel Lights
led bulbs in there. Replace the switch itself. I've done the swap in the past and takes a few minutes when done properly.
..and here's a cheap place to order them from. If one or two are out, just order up all 4 part numbers and do them all at the same time...the others are probably not far behind. http://www.gmpartsdirect.com/results.cfm
2003-2007
Rt Switch radio control #1999443 $14.50
Lt Switch Radio Control #1999442 $16.94
Rt Switch Info Center #21997739 $17.84
Lt Switch Info Center #21997738 $14.61
Remove BOTH battery terminals from your battery.
Wait for the power to discharge from the airbag.
Remove steering wheel.
Each switch is held in place and has a tab to be released. Don;t force them out.
There is a more detailed step by step here (SEARCH FUNCTION) that tells you how to change these out easy enough. Dont; be intimidated by teh airbag either. Just use caution and take you time.
Old 11-29-2010, 03:24 AM
pat123's Avatar
Cool Re: Steering Wheel Lights
Thanks; I appreciate the info.
Old 11-29-2010, 06:08 PM
H2 Bill H2 Bill is offline
I've done all of mine and there is no reason at all to remove the steering wheel. It takes about 2 minutes to replace each one.
1994 Chev Suburban Blown
Old 11-30-2010, 05:42 PM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
As long as you are one of the lucky ones that has a little play in the wire harness behind the plug. My dealer tried to replace one of my switches under warranty this way and they wound up splitting the foam around the switch and had to replace the steering wheel (not to mention they broke the wire harness plug trying to fight to get the plug back in...
Old 11-30-2010, 06:06 PM
If you have an "L" shaped "dental" tool you can manage it.
Old 12-02-2010, 02:54 AM
Thanks guys.... Other than hook up my new train horns (I took the old set off when I had the conversion done) replacing the lights in my steering wheel (which died within the last month) was the last thing I needed to do.
I was going to log onto tonight and read up on it.
Ya'll just saved me some time....
Thanks,
Mark
Old 12-03-2010, 12:50 AM
Just an update. I received my switches this morning. They're closer to 30 bucks a piece but nonetheless, it was as Bill said, a 2 minute job.
Once you have the new ones in your hand, you can see the arrow clips on the backside and if you take an "L" pick, you can slide it down inside and turn to release them.
I only replaced my two uppers since that's all that was needed. The wiring is indeed tight but using the "L" pick again, you can pull the plug upwards and snap it into the switch.
Thanks guys....
Mark
