Old 01-09-2011, 07:18 PM
myrddin myrddin is offline
myrddin is on a distinguished road
Default Front Hub Replacement Help (what do you think)
Hey guys, I am going to get some parts I need for repairs. I have an odd knock in the driver?s side front under my feet when I turn sometimes sounds like something slapping the floor at times, I suspect a body mount... However on the other side I seem to have a bit of play in the up and down (vertical) movement of the wheel and when I am turning left I get an embarrassing howling noise... This I suspect to be the Hub.
To get to the point. I have found a deal on two hubs for a bit over 200.00 and you get a few lifetime warranty.
See info:
BUY FROM MAC AUTO & GET THE MAC DOG WARRANTY , LIFETIME ON ALL OUR Wheel & Hub Bearing Assemblies
This item is for TWO BRAND NEW OEM style replacement Wheel & Hub Bearing Assemblies for the Front of your Car , Truck , Suv
FITS
* 2003,2004,2005,2006 HUMMER H2 All Engines
INCLUDES
* PART # 515058 PTC
ALL OF OUR HUB & BEARING ASSEMBLIES FEATURE
* 1/ HIGH QUALITY OIL SEAL
* 2/ INTEGRAL RACEWAY. TO PROVIDE PROPER BEARING CLEARANCE
* 3/ OEM APPROVED DESIGN
* 4/ OEM ABS SENSOR AND PLUG , AND ALSO ABS TRIGGER WHEELS WHEN REQUIRED
* 5/ LIFETIME WARRANTY FOR AS LONG AS YOU OWN YOUR CAR
Will this work for me? I figure even if they only last 3 years I may get another set free to fix down the road...
Please let me know, I would like to order and be done with it.
thnx guys.
Old 01-17-2011, 08:53 PM
HumminNBoatin''s Avatar
Default Re: Front Hub Replacement Help (what do you think)
Sounds like the way to go as H2's eat hubs.... Especially if you have oversized tires and go wheeling. Just ask them what the return policy is. I am betting you will pay for shipping etc....
Both the the problems you quoted with your own answers sound to be correct.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 01-17-2011, 09:10 PM
slippy slippy is offline
slippy is on a distinguished road
when my hub went out i looked at oem style hubs for the best deal on a quality hub. i ended up getting oem hub and had a buddy help me replace it. not sure if your after a good deal or best quality but that is an option.
also for non oem i hear good things about timco hubs.
Old 01-18-2011, 12:08 AM
Yeah, I ended up going with:
TIMKEN SP580310
Axle Bearing and Hub Assembly
$ 154.79 $ 0.00 1 $ 154.79
Had some good feedback, some said the lifetime deals worked out but they were replacing often. I will give this a try and see.
