02-08-2011, 02:03 AM
cant find a water leak
I have a water leak on my drivers side floor. I sealed the top light marker but still seems to have water coming from some where. Who sells the seals for the little marker lights over top the window . Dont think thats it since the roof liner isnt wet.
02-08-2011, 05:36 AM
Re: cant find a water leak
best advice is to get some clear silicone and pop each light up and silicone around it.
plenty of posts on this forum on this very same issue, as well as the remedy above to fix it.
02-08-2011, 08:40 AM
Yes.
Carefully pop up the front marker lights, clean the surfaces and apply either black or clear silicone sealer and reinsert the lights. Make sure to push them down securely.
Also, another thing to check is the drain tubes inside the front of the sunroof. Those 2 tubes can get clogged if not kept clean.
02-08-2011, 02:08 PM
the right and left marker light usuually leak underneath where the light wires come up through the door pillars, Be sure to look underneath the lights for a rubber grommet around the wires which go down into the pillar. Many times the grommet will come loose and water will drain down on to the floor in front. Clean around the grommet and seal around it with RTV ad push it back in place. The put a second coat of RTV around it. The grommet pops out of the hole due to air pressure coming up the door pillar when you slam the door
2004 Black H2
02-08-2011, 11:43 PM
On that note... where are the sunroof drain plugs again????
2003 Black H2:
2006 Blue H2:
02-09-2011, 01:09 AM
Not much info, sorry, Ed
