Old 01-24-2011, 05:53 PM
Hummerguy32 Hummerguy32 is offline
Hummerguy32 is on a distinguished road
Default How to: Light bulb replacement on gauge cluster area
When my gauges are lit on my 2003 hummer h2 the area that's is no longer lit is the mph range from 0-40mpg. Any solution on how I can get this fixed? Thanx in advance for your suggestions.
Old 01-26-2011, 12:07 AM
Default Re: How to: Light bulb replacement on gauge cluster area
I started to find out how to remove the cluster and get at the bulb. Hope this link helps anyone else.
http://www.2carpros.com/questions/2003-hummer-h2--2
Old 01-26-2011, 12:32 AM
Easy Ed Easy Ed is offline
I went through the 2003 service manual when you first made the post and I didn't see "bulb replacement" anywhere in that chapter that would of helped you
If you get it apart and find that the bulbs are something that can be changed please post pics.
I had mine go out/flicker once and just let it go when it came back on and has been working since. I fear it will be a matter of time before it does fail and your pics could be helpful.
Thanks for the link and posting.
Ed
Old 01-26-2011, 01:49 AM
Ed
No problem. I will post pix when I get to it. Thanx for lookin in the manual for me though.
