Old 04-29-2011, 04:45 AM
tyler1bo's Avatar
tyler1bo tyler1bo is offline
tyler1bo is on a distinguished road
Default Check Engine light keeps coming on
Ok guys my Check Engine light keeps popping up on my SUT..It's just the light, not the blinking one so I'm sure it's not a big deal..I took it up to my local Chevrolet place and they thought it was a bad gas pressure sensor. It hasn't been 2-3 weeks later and the light is back. Any ideas why that is?
Thanks,
Austin
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
Old 04-29-2011, 10:47 PM
twr's Avatar
twr twr is offline
Default Re: Check Engine light keeps coming on
Hi you need to read the codes! that light will come on for alot of reasons.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 04-30-2011, 02:20 AM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
Buy a ScanGuageII and find out what codes the truck is generating. Then you will know where to go to solve the problem. Chech engine lights come on for a hundred reasons!
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 04-30-2011, 03:25 AM
tyler1bo's Avatar
I know it's probably not a big deal, but it gets old after awhile! My truck is running just like normal..I'm almost thinking it may be from my K&N filter?
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 04-30-2011, 02:40 PM
I am sure that it is both annoying and frustrating! Especially when there is no apparent reason for the check engine light. But, there is a solution and that is in my previous reply. I get check engine lights on both my H2 and H3 occassionally and for no apparent reason. The ScanGuage will let me pull the codes and clear the check engine light. Problem solved.
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 04-30-2011, 05:24 PM
tyler1bo's Avatar
Thanks for the help..I'll look into that
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 05-03-2011, 08:07 PM
surf twang surf twang is offline
surf twang is on a distinguished road
Same thing happened to our 2006 H2. It turned out to be a bad catalytic converter.
Old 05-04-2011, 12:07 AM
tyler1bo's Avatar
Well the light was on this morning, then I turned it on later that day and the light went away. Haven't had it since. Don't know what it was.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 05-14-2011, 05:19 AM
draconianruler draconianruler is offline
draconianruler is on a distinguished road
Is there a way to pull up the engine codes without a scan tool?
Old 05-14-2011, 01:30 PM
HummerJim's Avatar
Autozone will read your codes for free. I had a similar problem with my old H3 and it turned out to be the pre cat O2 sensor. There is a history and some old threads about the gas caps going bad and giving the check engine light. I'll see if I can find you the link. I have the GT1 diagnostic software for my laptop and the Hummer plug in and I love it. You can use it on all domestic cars and BMWs, Porsches and Mercedes if you get the proper cables and plugs.
